  #21
Old 05-14-2013, 03:20 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by Mel View Post
It is not the responsibility of the DAR to see that TSOs are met.
That is the responsibility of the owner/operator.
Same goes for the transponder/altitude reporting system, lighting systems, etc.
It is the DARs responsibility to confirm that the aircraft meets 21.191(g).
21.191(g) almost says diddly -
(g) Operating amateur-built aircraft. Operating an aircraft the major portion of which has been fabricated and assembled by persons who undertook the construction project solely for their own education or recreation.
Essentially, if that is your only criteria, all you need to do is check the 51% rule and issue the certificate...
There must be a few more FARs a DAR must follow...
You don't confirm the aircraft meets the requirements of 91.207?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-14-2013, 04:16 PM
Mel's Avatar
Mel Mel is offline
How many FSDO inspectors have you seen checking the TSOs on equipment installed on Amateur-Built Aircraft?
Most everything a DAR inspects is to help the applicant make sure that the aircraft is in a condition for safe operation. This is NOT a requirement, it is simply why most builders opt for a DAR.
Reality check:
How many RV-8s are certificated?
How many of them do you think comply with the ELT TSO?
The RV-8 was simply not designed with this in mind.
Again, final responsibility rests with the owner/operator.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-14-2013, 05:10 PM
Sam Buchanan's Avatar
been here awhile
Yep, I think it is safe to say there are absolutely zero ways to install an ELT antenna on an RV-8 per the TSO. The sliding canopy design makes a "legal" installation impossible.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 05-14-2013, 11:05 PM
az_gila's Avatar
Question
Interesting dilemma, How do you meet a required FAR when you can't?
Gil Alexander
Old 05-15-2013, 04:16 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default Mount it on the bottom of the fuselage
I spent considerable time contemplating this issue and concluded that my best option is to mount the ELT antenna on the bottom of the fuselage. In the event of a crash in which I am disabled and unable to activate the ELT myself, there is a reasonable probability that the fuse will be inverted and the antenna oriented just like the engineers and bureaucrats desire. Given the lack of reasonable alternatives in an 8, I just made the executive decision and left the rest up to the good Lord.
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
Old 05-15-2013, 06:01 AM
AirbusPilot AirbusPilot is offline
Originally Posted by az_gila View Post
That installation would not meet the required US TSO.
From the ACK-451 manual
The antenna must be installed VERTICALLY (within ? 15o of the vertical plane is acceptable).
Again, a rule bending DAR would be needed....
Hi Mel,
Yes you are right, I didn't meet TSO, but not because I want to, it's almost impossible to meet TSO in a RV-8 at least you modify the canopy. I choose to install the antenna under fairing because is where "mother ship" installed and I also I know it works even inside my hangar. I am building a second RV-8 and probably will do the same, I haven't see a better place to install ELT antenna here on VAF.
Fernando
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 05-15-2013, 06:20 AM
jthocker's Avatar
jthocker jthocker is offline
Originally Posted by AirbusPilot View Post
Hi Mel,
Fernando
Good for you Fernando!
I'm in the camp of "living life" and seeking "forgiveness" rather than watching others live life while "seeking permission"!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 05-15-2013, 06:27 AM
DanH's Avatar
DanH DanH is offline
I've heard of folks mounting them inside the wingtip. Same antenna orientation upside down or right side up, and the antenna cable doesn't pass through structure.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-15-2013, 07:57 AM
airguy's Avatar
airguy airguy is offline
Not sure I like that, the ELT G-switch really should be mounted in primary fuselage structure. I hard-mounted mine in the fuselage just behind the baggage compartment and put my ELT antenna under the fairing for lack of a better location.
Old 05-15-2013, 08:33 AM
jetdriven jetdriven is offline
The instructions say the antenna must be mounted within 30 degrees of vertical.
Byron
1977 Mooney 201
Houston, TX
