Old 05-12-2013, 05:44 PM
William William is offline
Default Fully Insulated Fast On Connectors with PIDG style crimp tool?
Hello everyone I've ordered these fully insulated fast on connectors http://www.waytekwire.com/item/30713...T--250-X--032/ to do a lot of the wiring in my aircraft. I'm using these PIDG crimp tool from BandC http://www.bandc.biz/pidgstylecrimptool.aspx. My question is I've read that people were having a difficult time crimping the fully insulated fast on connectors with the PIDG crimp tool I purchased. Is this tool not going to work for me? Should I purchase the fast connects without the full insulation?
thanks,
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 05-12-2013, 06:07 PM
rzbill's Avatar
rzbill rzbill is offline
I would not be concerned about the PIDG tool.
I WOULD be concerned about the connectors you are buying.
They appear to be automotive style rather than PIDG style.
It is quite possible that they are pieces of ****.
One difference is in the construction of the crimp area. PIDG connectors include a metal sheath that permanently crimps and holds the wire insulation.
Automotive styles have a plastic sheath that can be crimped but will not stay and will not provide strain relief.
I tried to confirm the sheath design but I cannot via the technical documents on the website. I can only assume they are what they appear to be.
You will be way better off by using real PIDGs and insulate them with heat shrink tubing over the sliding section.
Bill Pendergrass
ME/AE '82
Old 05-13-2013, 05:25 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
What you want is PIDG FASTON from AMP / Tyco
They are the proper stuff - Google it and you should get many direct link to suppliers in the US
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 05-13-2013, 09:21 AM
Thanks Bill and Jan I picked up the proper connectors from b and c.
Best regards
Bill
Finishing a RV10
Old 05-13-2013, 01:32 PM
Default Trivial Perhaps
PIDG = Permanent Insulated Diamond Grip. Not that I keep up with this stuff but there are requirements that can be missed by the casual user. In 1958 or early 1959 every electrical worker and every electrical inspector at McDonnell Aircraft (I was working the F-101B line as a R&E Inspector) had to attend an AMP class to learn those requirements so we did them right in the first place and we all knew what was acceptable and what wasn't. What can possibly go wrong? Well, surprisingly several things but after that investment I don't recall seeing a bad crimp.
The terminals you have a link to in the original post are the type I was supplied with the Electronics International CHT and EGT instruments. I used a regular terminal crimper that I bought from Radio Shack or Aircraft spruce (LOOONG Time ago). As all of the other posters implied or stated outright I just did the best i could to get a good conductor crimp. I stripped off enough wire insulation to allow me to fold back the exposed conductor because it is small and extra cross section is required to get a reliable strong crimp on the terminal conductor crimping barrel inside the terminal insulation and just took what I got with the insulation crimp. You might be able to work out a procedure with and extra sleeve build up on the wire insulation and get a little support there in the insulation crimp, I don't know. I just secured the wires on each side of the terminal interface for stabilization and strain relief.
Bob Axsom
Last edited by Bob Axsom : 05-13-2013 at 03:26 PM. Reason: Added second paragraph.
