Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-10-2013, 04:07 PM
TXFlyGuy TXFlyGuy is offline
Default Electric or hydraulic - Which is best?
Any thoughts on propeller design? Electric or hydraulic constant speed...which is better? Why?
Old 05-10-2013, 04:15 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
What engine and airframe??
What intended use of the aircraft??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-10-2013, 05:57 PM
The engine will be a V6, around 300 hp. A T-51 airframe. Aerobatic at +6 / -4.
Old 05-10-2013, 06:19 PM
Mike S's Avatar
Senior Curmudgeon
Is the PSRU even capable of supporting a hydraulic prop???
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-11-2013, 11:31 AM
Michael Henning Michael Henning is offline
Electric won't work well for aerobatics... too slow to respond.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-11-2013, 11:53 AM
Mel's Avatar
Mel Mel is online now
As stated before, the hydraulic is typically better for most applications.
Electrics are normally used where hydraulics are not available.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
