Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 05-09-2013, 03:33 PM
vasrv7a vasrv7a is offline
Default Lightspeed Plasma ignition wires
I have one Lightspeed EI and one magneto on my RV-7 (0-360) and have been flying it for 7 years (575 hours) with no ignition issues (EI or mag)... I have recently been told that the Lightspeed EI ignition wires should be replaced with new wires no longer than every 5 years.
I don't have any problems now that i can detect... can i please get comments on why and when i need to change out my ignition wires. What problems will i experience, and how will i know that i have any problems?
Please advise.
Thanx.
Victor
Old 05-09-2013, 04:10 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
What...? Not! Must be a salesman. Too many variables.
Oh, don't forget the muffler bearings every 8 yrs.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 05-09-2013, 07:41 PM
tadsargent's Avatar
tadsargent tadsargent is offline
Don't forget to change out the winter air in your tires ;-)
You have nothing to worry about
Tad Stripes Sargent
GRT HXr Glass
TITAN POWERED IO-370
Hartzell's advanced composite propeller
Old 05-09-2013, 08:29 PM
gasman gasman is offline
Wires are cheap. A bad wire can wipe out a coil. You could just test the wires and see if they are still in spec.
Or have a couple beers and call Klaus and ask why they need to be changed.
Report back here if you do.........
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 05-09-2013, 09:40 PM
deek deek is offline
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 05-10-2013, 05:19 AM
Walt's Avatar
Walt Walt is offline
Take a look at the info on the Manecor website, they elude to the fact that many of the "popular" high performance ignition wires will deteriorate over time. Good reading as well.
"Unfortunately, and particularly with the use of high-output ignitions, the outermost high-resistance conductive coating over spiral windings acting as the conductor will fail from burn out in the same manner as carbon conductors, and although in most cases, the spiral conductor will not cease to conduct like a high-resistance carbon conductor, any RFI or EMI suppression will be lost as a consequence of the coating burning out. The worst interference will come from the so-called "super conductors" that are wound with copper (alloy) wire."
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-10-2013, 06:53 AM
Default Well...
You can't put a "year" replacement on the wires. I know of builders that have had EI ignitions systems installed on their projects for longer than "five" years and they have never even started the engine. I would never advise them to replace them.
Reiley
VAF# 671
Friend of the RV-1
