Old 05-06-2013, 02:37 PM
PCHunt PCHunt is offline
Default Wing Walk Adhesive Question
Getting ready to install wing-walk anti-skid, ordered from Vans.
Is the adhesive that comes on the wing walk anti-skid sufficient, or have others added additional adhesive?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 05-06-2013, 02:57 PM
JonJay's Avatar
JonJay JonJay is offline
It is more than sufficient. Follow the instructions and make sure your surface is properly cleaned.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-06-2013, 06:44 PM
rzbill's Avatar
rzbill rzbill is offline
Just an FYI for builders that buy the adhesive ones that have letter cutouts. (RV7 etc)
When I came to apply mine, I searched for signs of the letter cutouts. Nada.
Looked hard too.
Called Vans to check that they sent me the right stuff. They told me to look harder. Hmmmff.. Was this a blowoff??
I did. Still nothing. Got kinda PO'ed. Kept looking and flexing and FINALLY a letter edge popped up. This was great because it helped find the same letter on the other mat. (In the beginning you can't tell even which end has the letters)
Anyway, they look great and stick great.
Bill Pendergrass
ME/AE '82
Old 05-07-2013, 07:35 AM
6 Gun 6 Gun is offline
Default walk
Be careful to hold on to the little middle parts because you have to place them back in the letter mine were so hard to get out of the cut that I messed them up.I really dont think they are made the best they could be!
Bob
Old 05-07-2013, 12:54 PM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Sticks just fine as is. I would recommend peeling out the letters before you apply, otherwise they are very very difficult to find.
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 05-07-2013, 02:00 PM
Norman CYYJ Norman CYYJ is offline
If you haven't already purchase the wing walk material Vans you could use skate board grip. Much cheaper and a lot better glue and a better grip to walk on. If the kids have a hard time wearing it out just think how long it will take you. I have done several planes with the stuff and it costs a total of around $12.00 for the entire plane.
Old 05-08-2013, 12:06 PM
Default Thanks
Thanks for the input, much appreciated.
RV-6, RV-6A, T-6G
ATP, CFII, A&P
Old 05-08-2013, 12:12 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I used this on the Sonex I built:
http://www.homedepot.com/p/3M-6-in-x...68NA/100391699
Worked great and lasted as long as I had the plane, and never even started to come loose.
On my RV-4 I purchased the Van's part and the only problem I have had is the very tip of the "4" started coming loose. I used a dab of Gorilla Glue under it and it has been fine since.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
