Old 05-06-2013, 10:02 AM
HFS HFS is offline
Default Anti-Collision Lighting for Day Only VFR
Am currently in the building process of a Day Only VFR -3 and have been reminded that I am required to have an approved "Anti-Collision Lighting System".
Having said that, any thoughts on the simplest, least intrusive system being used out there would be appreciated.
Thanks.
HFS
RV-3
S/N 11226 - Building
Old 05-06-2013, 10:07 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Thanks.
HFS
RV-3
Why do you have to have lighting? Who is requiring that?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-06-2013, 10:08 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Hey Dave, not sure but it would seem one of the electronic strobe systems would be pretty cheap and light, lots of folks seem to use them instead of the certified Whelens.
One example from a quick Google search.
http://www.strobes-r-us.com/closeup.asp?pid=286
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-06-2013, 10:22 AM
Low Pass's Avatar
Low Pass Low Pass is offline
FAR 91.205 b (11)
Old 05-06-2013, 10:28 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
To amplify Chris's response, I dont think it is required that you have anti-collision lights. You certainly can choose to put them on for a added safety benefit.
I believe that Part 91.209(b) is applicable to your situation. It only says that if you have anti collision lights you have to have them on....unless you decide it would cause a safety issue.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 05-06-2013, 10:29 AM
ccsmith51's Avatar
Originally Posted by Low Pass View Post
FAR 91.205 b (11)
But that is for standard category aircraft:
Sec. 91.205 ? Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements.
We have EAB certificates, so those regs don't apply.
Or if they do, I know a heck of a lot of EAB's that have no lighting at all and must be illegal...
Chris Smith
Carefully read 91.205(a). ....applies to aircraft with a standard airworthiness certificate....
If strictly day vfr you aren't required to have anything. But your operating limitations most likely require you to follow these rules for night or ifr.
Old 05-06-2013, 10:34 AM
Low Pass's Avatar
Sec. 91.205 — Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements.
Point taken on standard category. I can't say I know anyone who has set out to fly only daytime, but I also have never seen a (post-'70's) EAB without them (anti collision lighting). Better get that agreed to with your DAR before inspection day.
HFS - to unhijack your thread, my knowledge of new systems is limited. I know there are some impressive commercial LED systems available. I built a pseudo-home brew strobe system for mine out of Whelen strobe lamps and a mobile equipment strobe unit. It's still going after 13 yrs, but when it fails, I'm going to probably look at LEDs. Home brew teardrop array possibly. I use LED landing lights (MR-16s) now and am very pleased with the intensity, color and low current draw of those currently available.
One thing to consider if you go LED is to try and future proof it somehow (allow for replacement of your lamps). LED technology is increasing dramatically each year it seems.
Old 05-06-2013, 12:57 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Why would you not?
I cannot imagine anyone NOT taking advantage of reliable and (relative) inexpensive technology to help other aircraft avoid hitting you! It is not just your life you are protecting!
(Sorry for the rant!)
Old 05-06-2013, 01:07 PM
60av8tor 60av8tor is offline
May not be a concern of yours, but I would also consider the resale issue.
Jon
