How long should I do the pressure test?
I'm testing my right tank now using a home-grown manometer. I charged it to about 8" H2O and it has been setting for about 2 days. The pressure has varied mostly I think due to barometric presssure changes (.1" HG = 1.39" H2O), but it has held pretty well. Right now it's actually reading a little higher than when I started. The question is: how long should the test be run to rule out the possibility of leaks?
Ken Howell
Evans, Georgia
RV-7 N92LT - Based at Thomson-Mcduffie airport HQU
TMXIO-360, Dynon Skview
Flying since June, 2012
