Old 05-02-2013, 12:15 PM
AirbusPilot AirbusPilot is offline
Default UMA Tach sensor doesn't work with Garmin G3X help!!!
Dear Folks,
I am almost finishing G3X install in my plane but tach sensor from uma (T1A9) is not working and always reading 0, I have checked wire many times, only strange thing is that garmin manual connect white/orange wire to pin 58 which is +10 volts and not 12 as UMA requested, I have connected white/blue to 57 and white to 17, any help please
PD: second problem but minor is CHT3 is showing 85 degree, everything else shows 72, when I start the engine CHT3 got a X, everything else works (except rpm)
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 05-02-2013, 01:43 PM
Radomir's Avatar
Radomir Radomir is offline
try feeding the sensor from the battery.. that'd give you 12V that would rule out voltage as source of the problem..
Radomir
RV-7A sold
Old 05-02-2013, 01:58 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Hello Fernando,
The UMA T1A9 sensor requires between 5 and 24 volts according to the manufacturer's specification sheet, so either the +10V or +12V transducer power pin should be fine. Assuming you've checked the connections to the GSU 73, I would carefully check the wire colors on the sensor against the instruction sheet that came with it. UMA has been known in the past to use different wire color codes at different times, so you should always use the latest documentation that comes with your sensor.
As for your thermocouple problem, I suggest looking for wiring problems between the CHT probe and the GSU 73, including open circuits and reversed wires. You can also try swapping your #1 and #3 CHT thermocouples to see if the problem follows the sensor or the wiring.
- Matt
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 05-02-2013, 02:15 PM
Originally Posted by g3xpert View Post
Hello Fernando,
- Matt
Hi Matt,
From UMA
White/blue ground, I have connected to 57
White/orange +12, I have connected to 58
White signal, I have connected to 17
I could try to swap between 57 to 17, can I burn something???
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 05-02-2013, 02:28 PM
Default CHT number 3 is Ok now
I just change wire side from CHT 3 and is working OK, now I just have to fixs rpms
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 05-02-2013, 03:45 PM
Default Tach sensor
I checked tach sensor wires for continuity with a tester, there is no connection between the 3 wires with each other or with plane ground, but white/blue wire is connected with tach wire shield, is that normal, G3X said you should ground shield at GSU connector but shield is already grounded by white/blue wire, I think maybe sensor is bad
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 05-02-2013, 07:14 PM
Default Found solution on Tach Sender
Ok, after checking everything many many times and reading the manual till I know tach wires color and pin of memory, I was looking for info on the Internet, then I found MGL sensor installation manual, and that manual has only 14 pages, not 200 like garmin, but it was clear, I attached sensor in the wrong hole at magneto
Thanks MGL for write a great and very clear manual!!!!!
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
Old 05-02-2013, 09:34 PM
Brantel's Avatar
Brantel Brantel is offline
Same thing happened to a buddy of mine a few years ago when he was installing an AFS EMS. Glad you got it sorted out!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-03-2013, 05:20 AM
g3xpert's Avatar
Fernando,
Glad you got your RPM input working. You can also double-check with the manufacturer's instructions to verify the correct installation. We pride ourselves on the completeness and detail of our manuals, but we're always happy to get customer feedback to make them even better. I'll make sure to ask our technical publications department if they can do anything to make the instructions more clear in this area.
thanks,
- Matt
Garmin G3X Support
g3xpert@garmin.com
Old 05-03-2013, 06:10 AM
Fernando,
thanks,
- Matt
Hi Matt,
I think Garmin manual is very good and complete, but MGL have pictures that make the manual "fool proof"
Thanks for help!!!
Fernando Abasolo
Santiago Chile
VAF #2056
EAA Member 774981
