Old 05-01-2013, 08:24 PM
CMW CMW is offline
Default RV-8 AOA port locations
I'm installing the Advanced Flight AOA ports in my RV8 wing. The installation manual lists the chord wise location as: "6" forward of the wing skin break at the spar about 12" aft of the leading edge". These measurements conflict slightly. If I measure 12" from the leading edge along the chord line, I get a measurement of 6-3/8" from the wing skin break on the top and 6-1/2" on the bottom.
So, can someone clear this up for me. Should I just measure 6" from the skin break on both the top and bottom or use 12" from the leading edge on the chord line? Or does it matter?
Chris
Old 05-01-2013, 10:05 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I installed mine at 6" forward of the skin break, top and bottom - and the AoA is dead on, right out of the box (no adjustments were required).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-01-2013, 10:14 PM
CMW CMW is offline
Thanks Paul!
Chris
Chris
RV-8 Wings
