05-01-2013, 02:34 PM
Deluxe fuel caps worth it?
I'm starting my -7 wings and would appreciate someone explaining what's the advantage of the deluxe fuel caps, other than being lockable. Lots of posts say they are better. What's better about them?
thanks
Ivan Luke
Hope Valley, RI
RV-7 SB
Just hung the engine!
2020 dues paid
05-01-2013, 02:48 PM
I believe you can get them as locking (I didn't), and they are less prone to leak (water) than the stock caps.
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
05-01-2013, 04:25 PM
Give me a few days and I will post some photos of both types – The deluxe cap is a much nicer engineered product – Yes they both work .. but I would say the deluxe does its job “better” ... The deluxe cap is made in England by a company called Newton – Here is the link http://www.newton-equipment.com/
Are they worth it ? Yes I think so ..
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
05-01-2013, 04:40 PM
Fuel caps
They look a lot better then stock caps. I went with the non-locking type. Never a problem with leaking.
Don Patterson
RV-7A Slow Build, IO-360, Hartzell constant speed blended airfoil. CFII
First Flight Oct 6, 2010
05-02-2013, 05:35 AM
Thanks for the info. Several folks have commented on the issue of leaking. I assume people have had trouble with the stock caps leaking?
Ivan Luke
Hope Valley, RI
RV-7 SB
2020 dues paid
05-02-2013, 07:09 AM
Fuel lube
Keep the cap seal 'lubed' with fuel lube , which is similar to vaseline, and it will help keep water from leaking in when tied down outside. It also makes removal easier. A piece of tape over the caps also helps when on cross country.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
05-02-2013, 07:35 AM
Stock caps for 13 years. Lube with Chapstick (lube the mechanism and the big o-ring). Never leaked once, or ever had a problem with unauthorized access (not having locks) while on the road.
05-02-2013, 09:25 AM
The deluxe caps are easier to operate, though I've heard the standard caps can be adjusted to operate as easily. Most of the bulders' logs I've read indicate they're less likely to leak, though Idid have one that required a bit of fuel lube to not bubble on the pressure check. I went with Newton locking caps, but for the life of me I can't remember why. If I had it to do over, I think I'd go with non-locking. I have nightmares about losing the key on a cross country...
RV-7 TU 904KM (reserved)
Construction Log
05-02-2013, 09:45 AM
Excellent point about the key. Thanks.
Ivan Luke
Hope Valley, RI
RV-7 SB
2020 dues paid
05-02-2013, 10:22 AM
RV14 fuel caps?
Does anyone know how they compare to the fuel caps for the RV-14? I am about to build my RV8 tanks and am considering those VS the Newton's
