Targa strip coming loose at one end
Hey ? I am having trouble with a two inch section where my fiberglass targa is coming loose from the canopy (pilot?s side, the lower 2? of the targa strip. It is glued on with West Epoxy, and I scuffed the canopy prior to installation. This is the second time the targa has come loose at this same point, and it appears to be holding fine on the rest of the canopy. I?ve looked to see if there was anything physical that was prying it off when I closed the canopy, and so far I can?t find anything.
Wondering if there is a different adhesive that might work better? The only caveat is that is needs to flow freely enough to go in the small crack between the targa and the canopy?.any suggestions?
If I can?t find an adhesive solution, I?ve been tempted to just drill a hole and throw in a screw and be done with it.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
