Old 05-01-2013, 08:53 AM
idleup idleup is offline
Default E-Bus relay location...
Do you all place the E-Bus relay on the engine or cockpit side of the firewall?
Do you have any pictures?
Thanks.
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 05-01-2013, 10:30 AM
BillFear BillFear is offline
Default ebus relay
Ours was on the engine side of firewall. Brought in the 7.2ah backup battery. It was getting unreliable and I found a way to eliminate it. now just use a switch on the EXP bus panel to bring in the E bus battery and SD8 alternator.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 05-01-2013, 10:35 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Switch only here also.
Switch is rated at 30A as I recall, I used a DPST switch and paired the double poles, so theoretically doubled the rating.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-01-2013, 10:42 AM
Default relay
When I took out the Ebus relay I was shocked, it bet that thing weighs 2 lbs!
Bill Fearheiley
Old 05-01-2013, 11:00 AM
crabandy crabandy is offline
I just mounted mine on the fuse tray. The s7401? Relay I used was just ounces.
Old 05-01-2013, 12:08 PM
Thanks Guys. I like the idea of a switch instead of a relay but I think the whole point of using the relay was to get the power line that you could not shut off out of the cockpit right?
- Matt
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 05-01-2013, 12:59 PM
Wayne Gillispie Wayne Gillispie is offline
- Matt
That is my reasoning on unprotected circuits. Would I rather have a relay fail(that can be bypassed to get me home) or burning plastic, sparks, smoke and molten copper produced during a crash?
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 05-01-2013, 01:02 PM
Mike S's Avatar
Senior Curmudgeon
- Matt
Agree with the above, I put an inline fuse (30A as I recall) back at the battery.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-01-2013, 05:49 PM
rzbill's Avatar
rzbill rzbill is offline
- Matt
I used a switch. The line coming from the battery bus to the E-bus switch is fused on the battery bus so that is not a cabin worry. The line from battery, through the firewall, to the battery bus fuse block was a worry until I put a fusible link on it at the battery post. Fuse link recommended by an AI that I asked to give me a once over prior to first flight. I agreed.
Bill Pendergrass
ME/AE '82
