Go Back   VAF Forums > The Never Ending Debate Section > Tools
  #11
Old 05-01-2013, 08:47 AM
RV6_flyer's Avatar
I have been using a Chapman tool kit since before I built the airplane.
http://www.all-spec.com/products/432...FeeDQgodcUUAPg
Screwdriver, allen bits, and 1/4" square drive adapter.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-01-2013, 08:51 AM
aerhed aerhed is offline
General makes a little clicker ratchet that isn't too elegant, but is the shortest one I've seen. It comes with a phillips on one side, flip it to use the straight blade on the other side. Most guys grind off the straight blade so you can use a finger or a prybar on top. Like $6.
Actual repeat offender.
Old 05-01-2013, 10:54 AM
larrynew's Avatar
larrynew larrynew is offline
Picked one up at Sears just a couple of months ago. Craftsman on the handle and it was only about $6 or $8.
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 05-01-2013, 12:05 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Randy Thorne ----Sport Air Serv here on VAF, showed me these a few years ago, I bought two, one for the plane and one for the shop.
Even given them as gifts to a few folks.
TOTALLY happy with the tool, would recommend them to all RVers. Strong well built, fine toothed ratchet works well in tight quarters.
Husky 8-Piece Bit Ratchet Set
Model # 64723T
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-01-2013, 12:13 PM
SmilingJack's Avatar
The Chapman set is one of the best I have used.
You can cut a apex bit in half and really take advantage of the slim size for those tight spots.
John Mastro
RV-8
Old 05-01-2013, 12:36 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default vim hbr5
The husky tool is made by Vim Tools P/N HBR5 Check Amazon.
http://www.amazon.com/s/ref=nb_sb_no...rds=vim%20hbr5
RV6 built and flying
Bearhawk Patrol plans purchased
Old 05-01-2013, 12:46 PM
Mike S's Avatar
Senior Curmudgeon
Good info, quick Google search found the actual manufacturer's home page.
Made in USA even
http://www.vimtools.com/home.asp
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-01-2013, 04:57 PM
speyers's Avatar
speyers speyers is offline
Default Thanks
Originally Posted by Beer30? View Post
There is supposedly two of them at a Home Depot near me. I bought something similar at my local Lowes. I would be happy to check for you and work out shipping.
David
Thanks for the help! That was quick!
David Speyers
CFII, A&P IA
Denton, TX
Old 05-01-2013, 09:08 PM
az_gila's Avatar
az_gila az_gila is offline
I have the Sears equivalent - I don't use it often but there are times when it is the only tool that works
http://www.sears.com/shc/s/p_10153_1..._tnt=39869:4:0
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-02-2013, 07:31 PM
speyers's Avatar
Default I don't always...
Hahaha, made me think of this:
David Speyers
CFII, A&P IA
Denton, TX
