Old 04-30-2013, 02:06 PM
jet_pilot jet_pilot is offline
Default Looking for certified engine mechanic/ workshop
Hi,
can somebody recommend a good and certified mechanic or engine workshop?
got an O360 A4A that was overhauled in 1980, but without documents and therefore FOCA asks for inspection,
work to be done:
-needs to be disassembled, all parts checked and reassembled
-install new FI
- install 2 Pmag
- install new starter
- dyno test
- issue service tag
UA
Old 04-30-2013, 02:45 PM
airguy's Avatar
airguy airguy is offline
Where are you located?
Old 04-30-2013, 03:10 PM
Kahuna's Avatar
Kahuna Kahuna is online now
JB Aircraft Services.
Sebring FL.
Been in business for years. A man and business you can trust. Tell him I sent you.
http://www.jbaircraftengines.com/
JB Aircraft Engine Services, Inc
203 Challenger Drive
Sebring, Fl 33870
Phone: 863-655-5000
Fax: 863-655-5005
E-mail: jimmy@jbaircraftengines.com
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-01-2013, 03:00 PM
Default Switzerland
But looking for mechanic in USA as here it is too expensive
regards
UA
Old 05-01-2013, 09:19 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default Engine SHop
I used Zephyr Aircraft Engines in Zephyrhills Florida to overhaul my Lycoming O360 A4M back in 2008 and they did a superb job. I highly recommend them.
Old 02-27-2014, 04:40 AM
Talking Back and installed
Hi,
since some time, Engine is back from Zephyr Aircraft Engines and installed, looks great.
Just like to express my satisfaction for the recommondation and the great job from Zephyr,
Charlie allways took time to discuss best options for the overhaul:-)
Overhauled O360 A4A , now with AFP FI and 2*Pmag
hope to start it up soon...........
UA
Building RV-6A
Old 02-27-2014, 06:35 AM
rleffler's Avatar
rleffler rleffler is offline
My favorite shop to recommend is:
Barrett Precision Engines
rhonda@bpaengines.com
They built and/or overhauled many engines for RV'ers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-27-2014, 11:51 AM
Lycomingandgoing Lycomingandgoing is offline
I tend to use Quality Aircraft Accessories. Sales staff is great (especially Vanessa and Justin) and if you bypass calling them and order online, they ship free. qaa.com
Hope this helps!
Old 03-01-2014, 09:10 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Dyno test
Most shops do not have a dyno, so if you want a dyno test be sure to ask. I believe Barrett precision engines and Lycon aircraft engines both have dyno capability. With whoever does your dyno test, to ensure accuracy, make sure they use SAE net or equivalent protocol and correct the results for standard atmosphere. A dyno test that is not performed to a standard and then corrected for temperature and pressure differences isn't worth a lot...but is widely use in advertising. Good Luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
