Old 04-30-2013, 01:50 PM
DEWATSON DEWATSON is offline
Default ignition systems
I'm sure this has been discussed to death, but with new things being invented everyday, maybe its time for some updated opinions..........what is the best ignition system to install on an IO360 RV8?
Old 04-30-2013, 02:14 PM
DaAV8R DaAV8R is offline
Default The best?
Two Bendix magneto's.
You asked!
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 04-30-2013, 03:27 PM
deek deek is offline
Best for what? You will get twice as many opinions as there are options
A lot depends upon your flying, equipment installation, electrical system redundancy, etc. I use one impulse Slick and one LSE Plasma system with direct crank triggers. I personally would not use two electronic ignitions and would use a Bendix instead of the Slick if it would fit. I've used Slick/LSE on 3 EZ's with more than 4,000 hours aggregate flight time, and intend to use 1 Bendix and 1 LSE on the -14. I understand Klaus' system, know how it works, how to install and trouble shoot it, and am reluctant to deviate from what works well.
There are, however, a lot of good systems out there, including two Bendix mags!
deek
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 04-30-2013, 04:20 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
You asked!
End of discussion.
I wish I had two of them
The saying goes I would rather have two old worn out Bendix than two new Slicks!
For a whole bunch of reasons which are not going to be discussed here, in my opinion, knowing what I know, and for fault finding (not always magneto faults either) the mags will be better.
Others love their e/pmag and EI's though.
YMMV
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 04-30-2013, 04:27 PM
drakerv drakerv is offline
Agree with post 3.
Old 04-30-2013, 04:34 PM
Weasel's Avatar
Weasel Weasel is offline
I also agree with post 3. I have 1 bendix and 1 lse
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 04-30-2013, 07:14 PM
6 Gun 6 Gun is offline
Talking mags
I like Craigers 5 spoke chrome with wide tires.
BOB
Old 04-30-2013, 07:42 PM
N941WR's Avatar
N941WR N941WR is offline
I?m thankful my truck doesn?t have points and my plane doesn?t have mags. Enough with the 1930?s Technology.
I?ll take a pair of P-mags with mine any day!
BTW, you asked a very loaded question, one in which there are a lot of opinions mixed in with a few facts.
The real answer is to install the ignition you are comfortable flying behind. The rest is noise.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-30-2013, 08:22 PM
jclark jclark is offline
Default Yet another opinion ... but from your "homie"
Started "PJ" with a "Jeff Rose (ElectroAir) + one impulse mag. Liked it,
Started a different project with 1 Lightspeed + 1 impulse mag.
Changed out mag on "PJ" to a "P-Mag".
I have flown behind each. I like what EACH of them does.
They all make for faster starts, smoother engine running and the POTENTIAL for better gas mileage.
BUT, if you are considering a change, in MY opinion, the EASIEST change to get some of the benefits of electronic ignition is to remove the non impulse mag and insert a P-Mag. Add power. And with #1 @ TDC give it the "puffs" and timing is set.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 04-30-2013, 10:30 PM
crabandy crabandy is offline
Default The best?
Too general of a question. Variable timing and hotter spark make more power smoother running and less fuel with EI, auto plugs and wires, but the electrical system must support it. Mags are electrically independent but are a compromise due to fixed timing and require maintence. Are you building or flying?
I have a dual Bendix mag engine, I installed a single EFII and put my order in to have an engine shop convert a single Bendix mag for my engine. I'm glad the engine shop didn't start on my mag yet, the more I thought about it the more the mag didn't make sense. My electrical system is based on the aeroelectric's 13-8 with the SD8 aux alt, so I have redundant electrical power. I chose this architechture for greater flexability to power avionics as well as engine electronics. I put my order in today for a second EFII and cancelled the order for my mag. Price difference between the rebuilt Mag and EFII was $500ish, I'm guessing I'll break even pretty quickly not buying $20 plugs and a 10% fuel savings.
