04-29-2013, 05:16 PM
anyone try EFII electronic mag?
Just curious if anyone has any opinions about the EFII electronic mag.
http://www.flyefii.com/ignition/ignition_kits.htm
--2008 RV-9A
Austin TX
04-29-2013, 05:22 PM
A few posts about it over in the Electronic Ignition and maybe Fuel Injection forums. I believe crabandy is going through an install of one right now. I plan on getting it for my 9A, to replace the Slick Lasar system that came with my engine. Already working in the return fuel lines for it as I build my wings. Drop Robert an email, he's *very* knowledgeable about how his system stacks up with others.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
04-29-2013, 05:28 PM
Thanks.
I'm starting my planning for swapping out my right mag and would love a drop in solution. (o-320 rv9a).
--2008 RV-9A
Austin TX
04-29-2013, 07:54 PM
I've got most of it installed, just waiting on my prop and single mag to run the plug wires and install the plugs. Feel free to pm me for a phone if you like.
04-29-2013, 07:58 PM
EFII
Originally Posted by moll780
Thanks.
While EFII ignition is not a true "drop in" solution, I highly recommend it. I feel that it is well worth the extra effort to install it, especially if you're still in the build stage.
I have dual EFII units in my RV-8. Look Ma! No mags!!!!! Last week, comming back from our local "old folks lunch bunch" flight, I was at 5500 ft. 2300 rpm, 23 inches manifold pressure, doing over 155 kts. TAS while burning 5.9 to 6 gallons per hour. Not too shabby for an IO-360 angle valve 200 hp. engine.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
04-29-2013, 08:30 PM
Ideally I'd love to be able to just remove the mag, slap in the e-mag and presto!! But I am realistic.
What other options are there for e-mags (post build for an already flying -9A)?
--2008 RV-9A
Austin TX
04-29-2013, 08:42 PM
Hopefully you're not confusing EFII's electronic system with the real E-Mag / P-Mag. That's another option if you want to consider that, especially as a "drop in replacement". http://www.emagair.com Robert would rightly argue, though, that EFII's system is more comprehensive and probably more efficient.
04-29-2013, 09:01 PM
I'm liking the p-mag from emagair. seems like really just a drop in mag swap.
I'll reach out to them tomorrow to talk specs and get a how-to.
I'd like to get this installed before Oshkosh at my next service.
fun!
thanks for the info!!
--2008 RV-9A
Austin TX
04-30-2013, 06:11 AM
Being a auto and heavy technician, I really like the EFII set up, so do they have a true dual set up out now? Dual crank triggers ect?
04-30-2013, 06:50 AM
EFII
Yes they do! Call Robert Paisley at their listed number and talk to him. He hasn't updated the web site to include it. (At least the last time I looked.)
I have the dual crank trigger, dual ECU's and a backup battery in case the alternator goes TU. The dual crank trigger is attatched to one bracket, the same as the single one. The alternator belt/starter ring has 3 magnets in it. One is the top dead center trigger and the other two are the ECU triggers. Each pickup/ECU is programmed so that they know which trigger is theirs.
The backup battery is charged from the main buss and can be switched on if needed. It has a big honking schotky diode to keep it from discharging back into the main buss when it is running the ECU's. I use single pole double throw toggle switches to control which battery powers the ignition. The system also is regulated as to timing via a manafold pressure sensor.
I use one toggle switch for each ECU. The forward position is power from the buss. Center position is ignition off, and aft position is aux batt. power.
Hope this helps. I really like my system.
LAUS DEO
VAF788
