I need to hook my AvMap to my Trio EZpilot. I found where they both are talking the same language, NMEA 0183. when looking at the AvMap output it has a TXA(yellow wire) which I assume is the output I'll use to the Trio. I'm also use this line to my Dynon D180.
Below is the Trio pinout. Looks like I can hook my AvMap TXA wire to the #7 pin. Bt do I need to hook #8 to ground or leave it off or ?
