Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 04-25-2013, 06:58 PM
N941WR's Avatar
N941WR N941WR is offline
Default P-Mag auto plug life expectancy
I’m throwing this out there to see if others have experienced similar issues.
As the manufacture of the EICommander I answer a lot of questions (both on and off line) regarding issues with P-mags.
A month before my Condition Inspection was due my EICommander started giving me some odd readings regarding the health of my ignition. However, the P-mags were timed correctly, they were advancing in unison, they were both running the same configuration, the CHT’s & EGT’s were “normal”, and the engine just felt fine.
After going through every test, connection, and whatnot, I decided to change out the NGK BR8ES spark plugs with a new set. What the heck, I typically change them at every Condition Inspection, so doing it a month early was no big deal. Besides, they had about 105 hours on them. (I know, it was a slow year for me.)
The new plugs were gapped for .032 and installed. The old plugs were checked and the gaps were right at .032 and they looked fine. I could find no issues of any kind.
After changing them out, the EICommander reported all was fine.
Brad at Emag Ignitions, told me “There is some anecdotal evidence” that the plugs go bad at around 100 hours.
In discussing this with my partner in the EICommander, who flies a rotary powered RV-6A, I was sent this little gem:
Bill, having read about the ignition problem you refer to, I may have something to contribute.
As you know, I and most of the folks who fly rotary engine powered aircraft use regular automobile spark plugs. Most folks fly using auto fuel, but I and a few others fly almost entirely using 100LL av gas. What I and others have discovered is that after approx 100 hrs (it varies) on Av gas, the engine develops what we call "SAG" (Sparkplug Attention Getter).
The engine will take on a different note, rpm will drop and (in the early stages) after a couple of minutes things return to normal. The interval and duration of the SAG continues to increase - this can be quite disconcerting and lead folks off on wild goose chases trying to fix fuel and other problems.
We had one technical analysis which included cutting open the offending plugs - it appears that after 100-120 hrs running on Av gas the lead in the fuel gets deposited on the ceramic cone, also it appears that the continuous (hour after hour) of high engine rpm stress internal bonding of the auto spark plug components and leads to deteriorating spark performance. The only cure that we have found thus far is to replace the auto plugs.
So any time a new rotary flyer reports those types of symptoms, we tell them to change their sparkplugs.
Now without use of 100LL, those folks using auto gas generally get a several hundred hours or more - this SAG pertains to use of auto plugs with 100lL
FWIW
Ed
This is just food for thought. At less than $20 for a set of eight plugs, I now replace them all at 100 hours. Because of the cost involved, I don’t even bother with platinum plugs.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-25-2013, 07:33 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Thanks Bill. Just so happens mine are right at 100 hrs and my cowl is off for painting...guess I will go ahead a put new plugs in too.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 04-25-2013, 09:18 PM
Toobuilder's Avatar
Bill,
Do you check resistance of your new plugs before install, and did you check the "old" plugs? I've found all the new ones to be right around 4,500 ohms.
Longest I went was about 120 hours, but they were performing well- I simply replaced them because... Well they're cheap!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-26-2013, 05:22 AM
N941WR's Avatar
Good call Michael.
I just checked four of the eight plugs I removed and three of the four were between 4,200 and 4,3000 with one up at 4,500 ohms.
Bill R.
SC86 - Easley, SC
Old 04-26-2013, 07:11 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default BR8ES vs BR8EIX
Hi Bill - You may or may not have an opinion here . . . I'm running dual P-mags and am preparing for my condition inspection - just at 120 hrs on the top plugs - half that on the bottom since I added second P-Mag later. I currently am using the BR8EIX (expensive!) plugs. Any reason not to go with the cheaper BR8ES plugs?
Thanks!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 04-26-2013, 07:58 AM
Toobuilder's Avatar
Mark, I know you asked Bill, but let my throw my opinion out there.
The primary benefit to the exotic plugs is consistent performance with low maintenance over a long life. New car drivers would never stand for a plug change at every "tuneup" like back in the 60's. these plugs are used to make cars "maintenance free"...
That said, I'd keep them in there as long as they are performing. Do a visual inspection and ohm check every year, and call it good. JMHO.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 04-26-2013, 08:01 AM
dealfair dealfair is offline
Default Good info
Thanks mucho Bill. I'm a little over 100 hrs & burning 100LL. Have the plugs & cowl is off. Going to do the swap, very timely. Yes, at the lower expense and given the time, seems wise to go with the lesser plug.
Really appreciate the post!!
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 04-26-2013, 08:06 AM
Darn Mike, was typing my post then read this. Yeah, why not test & check?? Will do.
Deal Fair
RV-4 (N34CB)
Old 04-26-2013, 08:15 AM
rocketbob's Avatar
If 100LL were so detrimental to a spark plug's life then most massive electrode plugs would not last long. And this is not the case since I've seen them last over 1000 hours many airplanes including mine.
I think the BR8x plugs are too hot for a Lycoming.
On EI I run BR9ES plugs which I rarely replaced on condition inspections because I could see no visible wear. I easily got 4-500 hours on them and just replaced them even though they didn't need to be replaced
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 04-26-2013, 09:45 AM
MarkW's Avatar
MarkW MarkW is offline
Since I am not flying yet I sure can't argue with R Bob but I sure would be using the old color/condition method to find the correct plug.
I also can't imagine having to replace a properly choosen plug every 100 hours with or without lead.
NGK has an excellent website for that.
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
