Old 04-25-2013, 10:15 AM
V111Pilot V111Pilot is offline
Default Wicks Tach wiring question
We have an older wicks tach, and it seems to only be wired to one mag, what is the proper way to wire a tachometer? Should there be an input on the back for each mag? Currently when you do a mag check only the right mag indicates while the left does not indicate rpm (needle drops to zero).
Any help is appreciated,
Brent
