04-24-2013, 02:46 PM
Anyone else's skills lag behind their standards?
Begin rant:
To begin, I want my wing tip lenses to look like they're molded into the tips. One screw on each side holding them in, seamless transition.
My first set of wing tip lenses turned out horrible, I over trimmed them, they were crooked... just garbage. Ordered a new lens from Vans to start over. Second set came out much better. Taped them off completely, used Superfil to smooth out the transitions, sanded them down, popped them out... look great, although not perfect. While pulling one screw out, something grabbed and cracked the hole on one lense. %$!@#$!@#$^
On to round three. Trimmed it down, installed, another round of Superfil, sanded down, looking really good. Went to pop it out (just like the last time) and it cracked getting it out. #!%!@#$^@$%&%!@#$!~@#$%@#$^
I found an extra entire lens kit I didn't know I had.... so I'm going for round four. One of these days. When working on it doesn't just irritate me beyond the point of complete anger.
The only upside is one of them is really nice. I like it. The other is becoming a serious test of my patience.
End rant.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
04-24-2013, 03:04 PM
Perhaps you could use a cleco instead of a screw? My lenses are exactly as you describe but I did not build them. I check the torque occasionally and I am very cautious. I wonder if there are different manufacturers of these lenses and one is better than the other?
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
04-24-2013, 04:43 PM
That's the plan.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
04-24-2013, 04:57 PM
After throwing my first set in the trash due to my lack of skills, I ended up buying a set from Cee Bailey. They fit perfectly out of the box pre-trimmed.
04-24-2013, 05:10 PM
Only RV-10 lenses appear to be available from Cee Bailey
04-24-2013, 05:29 PM
Thought this was a safety topic concerning flying skills at first glance - to which my answer is a solid "Yes"...
But in the fabrication area, I too fall short of my own standards quite often. I'm a trained, experienced A&P with a breadth of fabrication experience and I do airworthy work, for sure, but not much I do is a source of pride. There is always something a little off that bugs me enough to just keep my mouth shut, or will cause me to deflect a complement from a bystander.
I just took another look at Cory Bird's "Symmetry" on display at Mojave the other day.... If you REALLY want to deflate your ego, compare your work to THAT airplane!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
04-24-2013, 06:44 PM
Skills versus standards
If you are a true perfectionist, there is no such thing as perfect. There is always some way to make it better. Only took me about 50 years to lighten up and get a life. Sometimes good enough has to be good enough.
Jim Berry
Rv-10
04-24-2013, 07:51 PM
Learning curve
On whatever pursuit, if I reach to point of being satisfied, I know I have stopped learning. The FAA has it right on this one, we build for our "education and entertainment." You will learn something on try #4. Don't lose heart.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
04-24-2013, 08:54 PM
Feel your pain
Sig, I feel your pain and I'm not even there yet. I'm struggling with these $:@&$?!$& empennage tips! Add filler, sand it off, and do it again, again and again. Just can't get them to my satisfaction. Suppose I may have to lower my standards a tad or this thing will never fly. And now I can look forward to fitting the lens covers-wow, just can't wait.
