  #21
Old 05-06-2018, 03:43 PM
Paddy's Avatar
Paddy Paddy is offline
Default Thought
Originally Posted by Phil View Post
Don?t over think it. Just do it and move on.
Or... since you are building a plane in your garage (), you could choose to think about everything very carefully... to each his own
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
Old 09-09-2018, 05:16 AM
Dustyone Dustyone is offline
Default VA-144 OVSZ Bushes
My Nose Landing Gear has always had some side to side play in it so this Annual I took the opportunity to install the Oversized Bushes that Van's sells.
2 x VA-144 OVSZ
The bushes come oversized and a simple measurement with some telescopic bore gauges will give you the correct size to machine your new bushes down to.
The Standard Bushes VA-144 measure : .750"
My Engine Frame/Nose Gear Mount measured : .760 ( average )
So I machined my new bushes to .758 ", applied fresh grease and reassembled.
I was rewarded with no detectable side play in my Nose Gear and an annoying clunking that was always there when I taxi or roll out after landing is now gone.
I don't know if the old bushes would of ever become a service problem but I am enjoying the reduction in play and noise in my front nose gear.
It should be noted that all these bushes require some service (grease ) and I would recommend that all owners plan to service these bushes at some time, maybe every 4-5 years.
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 700hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 05-28-2019, 11:40 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
With much thanks to Ashley whose post above describes exactly what we did, with ours being machined to 0.759" all i can say is wow.
Tracks much nivcer, not clunky all the time and flies about 30 knots faster
Seriously well worth getting this right.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
