Leaking brake master cylinder..
My right brake master cylinder leaks fluid at the top. The master is installed with the body at the bottom and the shaft extending upward. There are no external springs.
A friend gave me some new o-rings and said all I have to do is remove the snap ring, remove the shaft, replace the o-ring, and reassemble.
Now, in my experience that sounds way too easy!! I have searched the archives and not found anything that specifically deals with replacing these o-rings.
So, can anyone give me some pointers? Such as:
- Can I do this with the master cylinder body still connected to the pedal and the shaft disconnected?
- Does the shaft easily slide out of the body?
- Is there spring in the body exerting any kind of pressure on the shaft?
- Anything in particular that I need to watch out for?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
