Old 04-19-2013, 11:44 AM
Ronald Sutton Ronald Sutton is offline
Default Tip: Priming and paint
As a tech counselor I get called in to look over builders shoulders by request. If there is one over all complaint I have voiced; it is the priming of parts that mate to riveted surfaces. Often times there is too much primer used. When the finished parts are riveted together, the clinched rivet squeezes out the excess primer and shows a depressed area around that rivet. As you look down the line of rivets you can see it leaves a wavy line.
What is too much primer ??? I have been taught to prime just enough to see the base metal showing through the primed surface, all most a fog effect. Zinc chromate is a standard of the industry, and I use the simple spray cans.
Old 04-19-2013, 12:56 PM
Kentsrv7a's Avatar
Kentsrv7a Kentsrv7a is offline
Just don't use Liquid Plumber!!! LOL!!
Kent Stitt
[size="1"]RV-7A
TMX-IO-360w/ P-Mags, Hartzell CS Prop, Slider,
Dual Garmin G3X Touch w/ GTN-650
Old 04-19-2013, 10:45 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Wink
Hey now, I saw that.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 04-20-2013, 07:59 AM
Many builders are now using primers that have no intrinsic corrosion resistance except for being a barrier film. These primers need to be thicker to provide full coverage for protection.
With zinc chromate, a lighter coverage can be used because the zinc is protectve.
Dave
Old 04-20-2013, 12:12 PM
az_gila's Avatar
az_gila az_gila is offline
Dave
Or the strontium chromate in the AKZO epoxy primer which acts just like zinc chromate.
0.0010 to 0.0013 inch thickness is recommended and it will look semi-transparent.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-20-2013, 05:57 PM
deanmcole's Avatar
deanmcole deanmcole is offline
Be careful with zinc chromate. Unlike some chemicals that might cause cancer, zinc chromat DOES cause cancer. It is a known, proven carcinogen.
Dean and Donna
He's a Pilot by Day, Author (and RV-7 Builder) by Night
She's The Best Thing That Ever Happened to Him and an RV Builder to Boot
Emp Complete
SB Wings (Almost) Complete
QB Fuselage Received
Old 04-20-2013, 08:50 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Alodine (r) pen
Many of us started using the Alodine(r) pen for the rivet lines (original topic) several years ago. It eliminates the spray and when used per directions is a safe method to protect specific areas such as rivet lines. A single pen goes a long way and is extremely convenient.
P.S. The link I provided is not an endorsement. There are other sources at varying prices.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 04-20-2013, 11:15 PM
rjtjrt rjtjrt is offline
Alodine touch n Prep Pen.
Not sure how far each pen goes, or lasts.
I realise this is a difficult question but how many would you anticipate you would use for a whole kit if used for rivet lines only on mating surfaces?
My kit is RV-12.
John
Old 04-21-2013, 06:25 AM
rv7boy's Avatar
Forum Peruser
I can't answer your question since I haven't finished my wings yet. But I wouldn't buy but one pen at a time since it does have a shelf life. Keeping it in a refrigerator extends the shelf life.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 04-21-2013, 09:03 AM
aerhed aerhed is offline
$100 for an Alodine pen versus $42 for a gallon of the stuff? No thanks. I'll stick to papr towels, acid brushes and scotchbrite.
Actual repeat offender.
