Old 04-18-2013, 06:33 PM
airguy's Avatar
airguy airguy is offline
Default Source for Panel-power plugs for the panel?
I intend to run Base A20's with panel power but I can't find a source for the plugs that go into the panel - every search I run just pulls up the headsets with the plug on them, I can't find the panel half of the connection.
I know SOMEBODY makes these things - anybody have a source?
Old 04-18-2013, 06:51 PM
flyeyes's Avatar
flyeyes flyeyes is offline
The simplest way is to order them pre-wired from Bose. $31 in the online store with clear instructions.
You can find them cheaper, but usually only in larger quantities than you probably want. The small pins are a pain to solder, but the prewired ones take care of that.
James Freeman
RV-8 flying
Old 04-18-2013, 06:56 PM
rleffler's Avatar
rleffler rleffler is offline
Bose and ACS both sell the LEMO plugs.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-19-2013, 02:45 PM
roee roee is offline
Default Connector part number
A suitable bulkhead connector is LEMO / REDEL part number PTG.M0.6NL.LC65N
Google that part number and you should find a number of electronics distributors that carry it. As I recall, I got mine from Mouser.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 04-19-2013, 03:39 PM
airguy's Avatar
Thanks guys - found and ordered!
