Thanks Richard, Went to the hangar over lunch and measured - At the center of the blade chord (I am assuming that this is close to the props CG) I got 49 inches ahead of the wing leading edge which puts it at station 11".
I would estimate that 12.25" would be pretty close to where the prop hub bolts to the flange.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
