Booyah! Made the Big Cut.
That wasn't soooo bad.
70 degrees F. in Garage - Vans Supplied Cutoff wheel in pneumatic die grinder - Cut full depth on first pass - Properly supported and back-taped every 8" or so - edges (so far) sanded with 220 grit on an orbital sander - Pretty much a non event so far.
I about had a heart attack - I set the windshield piece on the plane and went to get the slider half, from across the garage i watched the windshield slide forward across the forward fuse and fall to the ground and bounce! I thought for sure that sucker was going to break in two... Whew!  Never get complacent i guess.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
