Old 04-13-2013, 10:19 AM
moll780 moll780 is offline
Default Left mag stuttering ... Replace with electronic or rebuild?
So with all my cold start issues someone mentioned that maybe I have a left mag issue...
This morning getting ready to go to Taylor for their fly-in and mag check... Left mag is running very rough with the engine sputtering and unable to keep a smooth rpm. Arg!
So.. Should I just rebuild or replace with an electronic unit?
Any recommendations?
--2008 RV-9A
Austin TX
Old 04-13-2013, 10:26 AM
FlyArmy FlyArmy is offline
When I get to that point I think I will make the switch to electronic.
Old 04-13-2013, 11:18 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
You don?t know much yet, you could have a fouled plug or just need to set you point gap in the mag.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
deek deek is offline
The fastest and cheapest way to get back in the air is, of course, re-build the mag. I've had two LSE systems with an aggregate 2,600 hours on them and will use one if I build the 14. If you go LSE, I recommend either the direct crank trigger or better yet, the mini sensor.
I've easily saved the cost of the LSE's in fuel saved; it's almost 1 gallon/hour at 17.5
deek
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 04-13-2013, 11:21 AM
gasman gasman is offline
That is your impulse mag. You want to keep that one, and replace the right one when it is time to go electronic ign.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 04-13-2013, 12:10 PM
arg.. so I take the cowling off and what do I find? Plug lead completely off on #2 and number 4 loose by 2/3rds turn.
re-attached and put everything back together and she starts up like a champ!
Cant believe it was something sooo stupid and thankful it was cheap!
But.. I like the idea of going with one LSE on the right mag.
What is the simplest and easiest kit to install?
--2008 RV-9A
Austin TX
Old 04-13-2013, 12:41 PM
bboecking bboecking is offline
Default Not to derail topic
I don't mean to derail the topic but I live in Austin and didn't hear about the Taylor fly-in. Where was it posted? Thanks.
Old 04-13-2013, 01:42 PM
right here in VAF.
http://www.vansairforce.com/communit...ad.php?t=84981
I recommend using socialflight. there is an app and you can set fly-in notifications.
--2008 RV-9A
Austin TX
Old 04-13-2013, 01:56 PM
mannanj's Avatar
mannanj mannanj is offline
Default Electronic
Look into Robert Paisley's EFII electronic ignition before you make your decision. I'm extremely pleased with mine. His ad is on the forums here.
I have his dual setup on my -8 and I easily save over a gallon per hr. at 7,500ft
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 04-13-2013, 02:45 PM
^^^^ Good advice
