Old 07-31-2013, 06:33 PM
Charles in SC Charles in SC is offline
Maybe someone can post a picture for us unbushingless folks.
Thanks!
RV 7
Old 06-20-2014, 12:38 PM
scard's Avatar
scard scard is offline
I'm looking into this now. At 1400hrs, we have real wear on the horn holes with elongation of about 3/32 (guess) at this time.I'm definitely thinking about making up some bushings to press into the horn if there is enough meat left. I too am interested in anybody's pictures. I haven't seen an RV with bushings specified.
Scott Card
CMW E-Lift
Old 06-20-2014, 12:44 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default What worked for me.
I had a similar issue with the rudder horn hole elongating on my old Stinson. The A/P that I worked with told me to go get some steel brake or fuel line that would fit the bolt, and to drill out the horn to accept the steel line in a press fit. I used a bolt, couple washers and a nut to press/draw/squeeze the tube in place.
Worked like a charm------hardest part was cutting the tubing short enough.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
