Old 04-10-2013, 03:22 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Question Cable throu bulkhead/panel, which one should I use?
Hello
I'm in the process to pull the wires into the panel and fuselage.
Now the question, which one should I use o these:
Should I go with the Rubber Grommet or with the Nylon-Bushings?
Which one will last longer or protects better?
Thanks alot, regards,
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 04-10-2013, 06:41 PM
cjhammes's Avatar
cjhammes cjhammes is offline
I used the plastic snap bushings. Much easier to pull wire through. I found this helpful as I found it much easier if you need to add another wire and pull through. The rubber ones create more friction vs. the plastic snap bushings allow the wires to slide through with ease.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 04-10-2013, 06:50 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Use the snap bushings. The wires will pull easier and will provide more protection from the sharp edge of the hole.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-11-2013, 09:32 AM
Hoss7 Hoss7 is offline
Default Plastic Snap Bushing.
Unless of an expensive variety, the rubber ones degrade, the plastic seems to last longer. Much easier to pull wire as the others suggest.
Steve
