Old 04-10-2013, 11:50 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Slider Frame Interference with Aft skin.
I think I've got my slider frame pretty well happy and inset 1/16-1/8" inboard of the fuselage sides and aft deck.... Problem is, now when I slide the frame back, the inside corners strike the aft deck skin as the pass by. I would bet this is pretty common. What are my chances this goes away when the bubble is on and spreads the frame?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 04-10-2013, 12:58 PM
airguy's Avatar
airguy airguy is offline
Fairly good chances - I had the same problem, caught it by about 1/32". You can also use an edge roller to roll the aft deck skin inward to give it a bit of "ramp" to ride up on instead of catching on the edge.
Old 04-12-2013, 07:44 AM
Scott_F Scott_F is offline
Had the same problem. Based on the advice of a very experienced local builder, I just trimmed the skin back a little bit.
Scott Fechtig
Patuxent River, MD
RV-7 - Finish Kit
Old 04-12-2013, 09:05 AM
MarkW's Avatar
MarkW MarkW is offline
Same issue. Called Van's and they said I could trim the turtle deck skin back. You can tell after the skirts on on that there is pleanty of meat left to trim.
Now that my canopy is finished it doesn't hit except the first skirt rivet catches. I like Airguy's idea. I think that would be just enough.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
