Old 08-07-2006, 09:31 PM
prporter prporter is offline
Default Lift reserve Indicator, but DIGITAL...have you seen one?
I want to put an LRI on my panel, but would prefer a digital one... has anyone seen one?
Old 08-08-2006, 05:27 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default No and I think analog is better
When I chose the LRI I had this in mind which I offer for your consideration:
  • totally independent of electrics
  • if mounted far upper left, can be accurately perceived with peripheral vision while looking outside which is where you should be looking when you are on approach and landing
  • less to go wrong
  • analog is provably easier to interpret for us mere humans
So, now you have the opposing view and - the wonderful part - can do what you want to do.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 08-08-2006, 07:17 AM
Awhile back, I had seen a digital unit that moved in an arc like the analog one, but was done with LED's in a circle.
Old 08-08-2006, 07:27 AM
Scud Scud is offline
Default LEDs
Here's a company that sells one with LEDs. No prices listed. http://www.lriaoa.com/kits.htm
Scott Barron
Abilene, TX
Got the tools. Empennage ordered.
Old 08-08-2006, 08:02 AM
praterdj praterdj is offline
What is and LRI? Is it similar to AOA? Probably a stupid question but I'm trying to learn.
Donald Prater
Formerly 52F now Arkansas...Go Hogs!
RV-8 Empennage Underway
N-284DP (Reserved)
Old 08-08-2006, 08:34 AM
RV_7A RV_7A is offline
LRI- Lift Reserve Indicator
http://www.liftreserve.com/
Very very nice instrument.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 08-08-2006, 02:28 PM
Thanks Jeff. I checked the website. Might have to add that to the list. Would this be necessary if I were planning on an AOA or would it just be redundant?
Donald Prater
N-284DP (Reserved)
Old 08-08-2006, 02:38 PM
That would be redundant. Im installing one in my plane. Its on my list as well.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 08-08-2006, 09:18 PM
Ted Radclyffe Ted Radclyffe is offline
Smile Circular LED LRI
I have installed one of the circular kits but have not had a chance to test it yet. 'Rough Red' (VH-ITR) is about to have the wings finally grafted on.
My observations are that the advantage of the circular indicator is that it fits exactly in the standard small instrument hole. The mechanical unit is a tad bigger. It catches the eye really well and goes dormant when there is maximum lift reserve (Cruise).
The LEDs are dimmable and have a sensor which automatically dims them to a predetermined level when the ambient light level falls.
On the unit I received, the warning sound (Required in Aust for IFR) is internal and is not able to be fed to the intercom. It is however quite loud. It can be switched off for aero's and there is a indicator LED to indicate that the warning has been disabled.
Fitting of the instrument is easy being mostly mechanical tubing and pipe work. There is a box to mount and the indicator is connected to the box with a meter or so of cable. I re-terminated the cable to get rid of all the additional wire but the intention is that the box which has the hose fittings can be mounted in any convenient spot and the indicator is mounted in the instrument panel.
I mounted the wing probossus in the aeleron bell crank cover near the pitot pipe. Taking off the fuel tank to 'P' clamp the tubes to the spar was a drag but if one didn't care so much they can be simply poked in the space between the spar and the tank.
Setup is a breeze with a protractor being provided to get the correct angle. Fine adjustment can be done at the instrument.
My observation is that the whole instrument is well constructed for the price, fits into the panel well, and is easy to see and interpret.
Next month when 'Rough Red' finally takes to the air, we will know if the choice was vindicated.
Hope this helps a bit with the choice.
Ted
Old 08-09-2006, 07:26 AM
Ted, did you install the circular LED or circular mechanical?
