Old 04-10-2013, 08:47 AM
rvator51's Avatar
rvator51 rvator51 is offline
Default need part number for flywheel belt
Does anyone know the part number for the belt on lycoming O360_A1A? Standard pulley. Its a gate v-belt but can't find number.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 04-10-2013, 02:16 PM
Larco's Avatar
Larco Larco is offline
Hi Tom, This what Plane Power suggests but not all alternators will use the same belt. The supplied 15355 Dayco V Belt will fit the 9 3/4" diameter ring gear support pulley, for applications which have a 7 1/2" diameter ring gear support pulley locally purchase XL7300 Gates V Belt or equivalent. Larry
Old 04-10-2013, 02:27 PM
Jeff A's Avatar
Jeff A Jeff A is offline
Mine is a Gates XL7355 (also has #10A0900 on it) using a Vans 60 amp alternator.
edit- 13/32" x 36-1/8"
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 04-10-2013, 02:45 PM
Gary 40274 Gary 40274 is offline
Default NAPA
I have found that the NAPA green belts last longer and work better than the Gates. YMMV
Gary
