Old 04-08-2013, 08:36 AM
Elwell81 Elwell81 is offline
Default 1st flight and phase 1 testing
I am currently building a -9A and am trying to look down the road a bit. I live about 15 miles north of Green Bay, WI and am contemplating which airport to start looking for hangar space. There is a small community airport (92C) less than 5 miles from my house but the runway is 2550' X 30' and my concern is the safety of flight testing with such a small facility. The other option is KGRB which is a Class C airport, which has (2) >8000'X150' runways. I know the obvious choice would be KGRB but I would prefer the smaller airport due to the proximity to my home, which I guess begs another question as to what stage of the build does the airplane need to go to the hangar and how much work is usually left at the hangar. Unless I'm mistaken, it seems like I could get most of the work done in my garage, short of installing the wings for the last time. Any opinions or comments are welcomed. Thanks
-Andy
Old 04-08-2013, 08:41 AM
Vern's Avatar
Vern Vern is offline
Default Bigger Airport better for Phase 1
Go for the larger airport. People take longer than they imagined after the airport arrival. Plan on at least 3-6 months even if you think it is done at home.
Although the shorter runway is OK for 9A ops, the 9 is a real floater and most guys I've trained would need the longer runway until they got the picture. Eliminate one more risk factor!
After your phase 1 and when you are comfortable, you can move to the more convenient location.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 04-08-2013, 08:43 AM
Bugsy's Avatar
Bugsy Bugsy is offline
30 ft not for me. I will be worried enough on my first flight to have to worry about x winds adding another component.
I thought about the same thing but I like have 150ft and a control tower to worry about traffic. I have never test flown an airplane. And safety margin is important to me. You can never have too much runway unless its behind you and you can never have too much gas unless your on fire.
You can build most in your garage.
Good luck on your decision.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 04-08-2013, 08:48 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Welcome to VAF!
Andy, welcome to the good ship VAF
For the first few flights, bigger is better for sure.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-08-2013, 08:59 AM
airguy's Avatar
airguy airguy is offline
I fly out of 2600'x35' on a regular basis in the 172 - but for my first few flights in the 9A I'll be moving it to a longer (but not any wider) runway. I want plenty of length to make decisions and get used to the aircraft performance before I bring it back to home base. With my narrow runways I simply won't be doing any early Phase I work with crosswinds. I still won't have a tower directing traffic, but I'll have a dedicated paved runway that's only shared by a couple cropdusting aircraft, so traffic will be easy to manage!
Old 04-08-2013, 10:32 AM
Don's Avatar
Don Don is offline
Andy, I have a flying 9A and another one I am working on doing the "finishing" kit. I think I have some relevant experience to share.
I bought the flying 9A and flew it home in November and now have about 45 hours on it. I would not do phase I testing at 92C because of the runway size, particularly the length.
Getting the 9A in and out of 92C won't be a problem once you've learned the landing characteristics of the 9A, and you've verified the accuracy of your ASI, and you've worked any bugs out of your plane. The 9A doesn't bleed off air speed like a 172. Ten or 15 extra knots on final in the 172, while poor form, probably wouldn't force a go around in the 172 at 92C. With a 9A the extra speed is going to result in a go around or be hard on the brakes, the nose wheel, or both - particularly if you land long.
It seems wise to me to put all the odds you can in your favor during Phase I. A bigger runway is certainly doing that.
Lastly, don't kid yourself that just because the 9A is easy to fly and to land, that there is no transition when going from a 172 to the 9A. The statistics certainly don't support it. My experience suggests there's not only a transition but that there are phases to the transition where you go from somewhat competent to increasingly skilled in various phases of flight.
You're going to love the 9A, too. It is a remarkable flying machine.
As for when to move to the airport - I'm not planning on taking mine out until I'm ready for final assembly.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 04-08-2013, 02:17 PM
esco esco is offline
Default Go Big, then go home
My two cents:
Suggest you go to the larger, parallel runway environment for Phase 1.
I've never (yet) used the complete 150' width of my home runway, but it's nice to have if needed. I'm a low time pilot, and in Phase 1; I won't go up when I know or expect significant crosswinds. Did have some unpredicted 15-18kt crosswinds oncet, and the 9a did very well... but I had a very wide target to work with.
As others discussed, some risks can be reduced through good transition training, good pilot technique, and... more runway. This came in handy for testing, and I have been very grateful, once or twice, to have 5000' of pavement when that amazing 9a wing demonstrated how well it glides in ground effect.
I also suggest talking to a DAR/FSDO to see what's available for a Phase 1 area - there might be a difference between the area associated with the different airports.
YMMV.
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
Old 04-08-2013, 02:33 PM
Mel's Avatar
Mel Mel is offline
Be aware that as long as the smaller runway is within your flight test area, you can land there during phase I.
I do recommend the larger runway for the first flights, but you are not limited to only that runway.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-08-2013, 02:59 PM
I would also ask: Is one of these airports surrounded by cornfields, and the other by houses or trees? That would make a difference in my decision.
Old 04-08-2013, 03:26 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Landing elsewhere... that depends...
The Hlllsboro, Ore FSDO did the A/W inspection for my -9A in 2010 and my Operating Limitations came with the restriction of only landing and taking off at my "home" airport until Phase 1 was completed! Others in the area that had DAR's do the inspection got carte blanc for practice airports in their area. So be aware that what others get might not be what you get, depending on WHO does the inspection.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
