Old 04-08-2013, 08:00 AM
aarvig's Avatar
aarvig aarvig is offline
Default Air compressor troubles...
I have a 26 gallon oil lubricated craftsman air compressor. Its been in storage for 6 months. When I pulled it out and started it up the tank would hold pressure, but when ever I adjust the line pressure it bleeds off tank pressure as well. Essentially, the tank pressure is always slightly greater than or equal to line pressure. Is this a regulator problem or check valve problem or something else?
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 04-08-2013, 10:32 AM
Sounds like a bad diaphram in the regulator. I don't know of any regulators that bleed off to the atmosphere when working properly.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 04-09-2013, 09:05 PM
aarvig's Avatar
Thats what I thought too. Thanks for reinforcing it. I'll order a new part today.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
Old 04-10-2013, 08:06 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Some of these compressors also have a check valve (to ease load on the motor at startup). That valve could be leaking as well.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
