Old 04-06-2013, 06:56 PM
bret's Avatar
bret bret is offline
Default Install before aft top skin?
I am not a limber or small guy, so just throwing it out there, what should you do-install before the aft top skins go on, so I am thinking, thread rudder cables, conduit for trim, tail lights and elt,.........what did you forget to run, and end up back there like all those cool pics on VAF show.
Old 04-06-2013, 07:03 PM
AltonD's Avatar
AltonD AltonD is offline
Run the rudder cables and install the exit fairings if you intend to use them.
Any wiring, adel clamps.
Before you put the forward aft skin, everything else. Static, pitch servo, ELT mount, Stobe power supply if you need one. I would go ahead and drill drain holes. The locations are supposed to be on the plans, but I never saw them.
I think you have already figured out it is a real pain to get back there.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 04-06-2013, 07:36 PM
If you think you might ever install a remote magnetometer, install a shelf back there or at least nut plates to receive one. It's a PITA to install one in a finished aircraft.
Old 04-07-2013, 05:41 AM
pierre smith's Avatar
...Install shoulder harness cables as well.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-07-2013, 06:12 AM
AltonD's Avatar
Best,
I think I did this, but the bolt gets in the way of riveting the skin. Do Drill the hole for the bolt.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 04-07-2013, 06:36 AM
bret's Avatar
I thought I remember some on here making a cool AHRS bracket in the aft fuse, so farthe plans are for a Dynon set up, but I won't be flying this for a few years, by then we might just stick an I Pad thing E on the panel and go.
Old 04-07-2013, 06:51 AM
You guys worried about crawling back in a -7 fuselage....it's not a big deal.
I've crawled back in the -8 fuselage to install an AHRS bracket and canopy rail, but did so with a cell phone just in case of emergency extraction.
Have no fear, you can do it!
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 04-07-2013, 07:25 AM
Paul K Paul K is offline
If you are going to craw back into the tail cone, don't forget to support it first with a sawhorse or something to keep it from reacting to your weight back there! Sinking feeling followed by a sickening thud and bump.... Ask me how I know. Hey Van's, how much for a new tail fairing?
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
