Old 04-04-2013, 04:00 PM
prkaye prkaye is offline
Default new tires, squeeking/creaking rubber
I just put on new tires. Now when I pull the plane around I hear a sound of rubber squeeking or creaking from one wheel. Does this likely indicate an undesirable condition?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-04-2013, 04:15 PM
bird's Avatar
bird bird is offline
Hmm if they are toed in or out that could be the case. Toed out is better than toed in on a taildragger. Perfectly in line should be best for a nose dragger.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 04-04-2013, 05:18 PM
Disregard... it went Away after pulling it around a bit more.
Phil
RV9A (SB)
Ottawa, Canada
