  #41
Old 04-07-2013, 10:10 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Originally Posted by L_Rocky View Post
Hi All,
As a long time lurker I'm over due for my initial post.
Cheers
L_Rocky
Chris, welcome aboard the good ship VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-07-2013, 06:38 PM
ILikePike ILikePike is offline
Default High temp?
Is the high temp cord nessessary for FWF? Whats the temp rating on zip ties anyway? I plan to use lacing cord and need to know if I need two kinds.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 04-07-2013, 07:45 PM
Walt's Avatar
Walt Walt is offline
You'll be fine with standard lace chord unless you're putting a turbine in your RV
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-07-2013, 08:11 PM
Mike S's Avatar
Senior Curmudgeon
Moved the thread to "electrical"-----too much good info here to get lost in the "General discussion" section.
This should make it a lot easier to find in the future.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 04-08-2013, 09:11 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
The nylon lacing is good for 250F and the polyester for 350F.
Polyester should be OK for most FWF locations if you keep away from the exhausts.
Your standard mil-spec /16 wire is only good to 305F anyway....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-08-2013, 11:19 AM
SteinAir SteinAir is offline
As Walt said, just buy the standard stuff and call it good. You spend your time quoting and or spec's ad nauseum....or you can go build the plane (this is what we call the difference between theorizing and building)!
Speaking from experience, Walt is correct, standard stuff is fine. No need to get lost in details when the "normal" stuff will work perfectly for most everything in our RV's.
Just my 2 cents as usual!
Stein
Old 04-08-2013, 09:01 PM
az_gila's Avatar
Smile
Stein
Stein,
I agree, however in this case there are actually two standards if you buy from Aircraft Spruce.
If you are concerned about FWF temps then the cheaper "standard" polyester stuff is actually better....
Gil Alexander
Old 04-21-2013, 08:28 PM
splevy splevy is offline
Please excuse the slight hijack, but I am trying to find a source for mesh tubing I have seen used for harnesses. It has a fairly open mesh, is black in color, and seemed to have some "pull to shrink" capability. Any suggestions would be appreciated.
Stan
Old 04-21-2013, 09:12 PM
9GT's Avatar
9GT 9GT is online now
SteinAir has it. http://www.steinair.com/storedetail.cfm?productid=393
David C.
Howell, MI
Stan
We stock a standard size that works for most all of your needs.. You'll see it on a lot of harnesses we build (kind of like lacing cord, believe me and Walt when we say the "standard" black stuff works fine). It goes by the name of expandable tubing or sleeve....otherwise known as "snakeskin".
Stein
