Old 04-02-2013, 08:20 AM
prkaye prkaye is offline
Default Condor Tires Pireps?
It's time to replace my main tires. My vans supplied ones didn't last long, so I want something better, but don't want to break the bank. Aircraft Spruce is more convenient for me than Desser, because I live in Canada (shipping and brokerage gets bad). Anybody here have experience with Condor 5.00-5 6PLY ? How do they fare over time compared to the Aero Classic tires vans supplies?
I'm thinking I won't bother replacing my tubes, since they have less than 200 hours and are holding air quite well. Opinions?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-02-2013, 08:25 AM
FLY6 FLY6 is offline
Default Condors
Although I don't personally have experience with Condor tires I did have them come highly recommended by an AME when I was speaking to him about tires. He had nothing good to say about Air Trac and said Air Hawk was a step up but said he felt the best bang for the buck was Condors.
Hope this helps, Al
Al Grant
Flying RV6, O-320, 160hp
Burlington, On
Dues Paid
Old 04-02-2013, 08:42 AM
tommylewis's Avatar
tommylewis tommylewis is offline
Default my experience
Since I switched to Condor tires for my RV7a three years ago, I have had 4 flat tires! More flats than I have had in the previous 30 years! In my opinion, the condor tire is harder on the tubes which results in a wear spot pin hole leak. Running the tire pressure higher seems to help delay the leak, but it still happens. I have the 4th flat to fix today so we can fly to Sun n Fly. I will ever use Condor tires again!
I never reuse a tube and many others do not either because it is stretched out and is likely to have folds when reinstalled which also results in a leak.
Good luck
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 04-02-2013, 08:43 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Condor tires (Michelin's bargain line?) have always had a good reputation as used on typical Cessna and Piper spamcan trainers. I've never used them myself either, but have used AirHawks on my old Cherokee and they lasted an exceptionally long time for me. Both ought to last quite a bit longer than the original Aero Classics, which I've noticed always seem to wear out pretty fast too.
I recommend always use new inner tubes when replacing tires. It's cheap insurance since a blown tire on landing can potentially result in wrecking your whole airplane. It doesn't bother me at all to spend an extra hundred dollars on a pair of new tubes, just for a little more peace of mind... and the Aero Classic LeakGuard tubes do an awesome job at holding air.
Neal Howard
Airplaneless once again...
Old 04-02-2013, 08:46 AM
Sam Buchanan's Avatar
been here awhile
Phil, you might take a look at the retreads available at Aircraft Spruce. Retreads seem to enjoy a good reputation among the RV community. I've used them for the past few tire changes and have been pleased with the service life and price.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 04-02-2013, 09:04 AM
Hmmm, the GY Flight Special II are also in the ballpark of what I want to spend - much less than the Flight Custom III. Maybe these would be a good bet.
From what I've seen on the forums, I want either Airstop or Leakguard tubes?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-02-2013, 09:36 AM
walkman's Avatar
walkman walkman is offline
Default Be carful e on the retreads
I bought retreads from desser and had two issues. First, the casing on the tires was in pretty bad shape, will probably not last any longer than another year. Second, the retreads can be significantly thicker. I have the old style wheel pants and had rubbing on the pant.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 04-02-2013, 09:51 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
I've had wonderful luck with the Condor 6-ply rating tires.
I'm on my second set now. No flats.
I think I got about 450 hours out of the first set.
I wouldn't buy anything else.
Sorry to hear that Tommy has had trouble with them.
Mark
Good luck
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 04-02-2013, 01:16 PM
Neal@F14's Avatar
I have Leakguard tubes on my RV-6. I've only had to add air once since I bought the plane in May 2012. I put a new set of Leakguard tubes and AirHawk tires on my old Cherokee in 2008. I didn't have to add any air to those until I sold it in 2011 and it was only down a few psi.
Neal Howard
Old 04-02-2013, 01:41 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default My thoughts
I had some decent wear on my tires at 250 hours, so I just replaced them. Also I had a tube blow on landing last fall..not much fun so this is an area I feel its not worth being cheap on and I am happy to spend on good quality.
I went with ACS for the michelin airstop tubes. Excellent tubes, valve fits much better and I think the quality is very good compared to vans tubes. For tires I read a lot of reviews and while some think the retreads are great, I had some concern about the thickness and how it would fit my fairly tight wheel pants.
So...mich airstop tubes and vans tires. Will replace the mains every few years as needed.
Having a blow out at a field that isnt your own and without proper tools is MOST unpleasant. Dont scrimp on the important stuff. Just my 2 cents.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
