Old 04-02-2013, 02:54 AM
JRV JRV is offline
Default Heatshield Mat
Hi,
Does anyone have any experience with this product. Good or bad?
Thoughts or comments welcome.
Heatshield Mat
http://www.flyboyaccessories.com/sto...roducts_id=203
(Good service from these guys by the way)
or the link for the manufacture
http://www.heatshieldproducts.com/pr...ield-mat/76/21
It sticks to the firewall engine side. Stops some of the engine heat coming through???
Thanks for input
Jason
2015 Donation Paid
Old 04-02-2013, 08:15 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Search function
You might want to do a search for Dan Horton's definitive study on this subject. He ran actual tests and has much to offer on this.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 04-05-2013, 08:56 PM
vfrazier's Avatar
vfrazier vfrazier is offline
We know that Dan Horton doesn't like this product, but we don't intend for it to keep fire out. That's the firewall's job.... until the aluminum belly burns through, or other nasty failure occurs... ugh. Or you die in the crash after you shut off the fuel.... etc, etc. Not trying to start an argument, just pointing out that if you want safety, don't fly. Of course, you'll die of boredom instead. Something will get you.
Heatshield mat is quite helpful if you've got typical hot RV feet. I have found it to be quite useful for making at least 2 of my RVs (one is a Rocket) much more tolerable in the summer.
If this isn't in your comfort zone, please choose another heat proofing method.
Please let me be clear, I'm not ragging on Dan. His methods are spot on and 100% valid, but might be overkill for some situations. I just wanted cool feet during normal flight. I wasn't looking for extra fire protection.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 04-05-2013, 09:16 PM
DanH's Avatar
DanH DanH is offline
I don't have a problem with it. Primum non nocere. It surely does as Vince describes (provides some reduction in ordinary engine operating heat transferred to the cabin), and it can't increase fire risk if installed on the engine side of the firewall. For sure it is smarter than some of the really bad insulation choices folks install on the cabin side of firewalls.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-05-2013, 09:28 PM
flyingriki's Avatar
flyingriki flyingriki is offline
I use it on fiberglass cowls. It needs to be replaced relatively often (near real heat) and I have burn spots on the outside of my cowls within 3/4 inch of the exhaust where I left it for too long. I think a double layer works better. Away from the exhaust one layer works fine.
I've seen (I think) a layer of fiberfrax tight to the glass and a layer of aluminum floated about 1/16" above on washers work much better and will try that soon. Will have to do some digging in my archives for that combination and the installation to be sure. I'll guess someone here knows that process?
Old 04-06-2013, 06:37 AM
DanH's Avatar
Originally Posted by flyingriki View Post
I've seen (I think) a layer of fiberfrax tight to the glass and a layer of aluminum floated about 1/16" above on washers work much better and will try that soon.....I'll guess someone here knows that process?
No washers, no float. "Shadow" the pipes with 3" fiberfrax strips and capture it under HD self-stick aluminum foil from the Vans catalog.
Caveat; someone reported an incident where this kind of shielding came loose and blocked the cowl outlet. I've not had any sign of adhesion loss, but the inside of the cowl is sealed and painted so the stuff sticks very well.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-06-2013, 10:37 AM
KCBerner's Avatar
KCBerner KCBerner is offline
Default Dan's Study
By the way, here's the link to Dan's study. I keep this one bookmarked for when I get there.
http://www.vansairforce.com/communit...sulation+tests
K.C.
RV-14A #140026
Wings 70%. Emp 70%
Happy to be a 2020 =VAF= contributor
Old 04-07-2013, 09:04 AM
vfrazier's Avatar
Dan's cowl insulation method looks very nice. He sure makes it tough for the rest of us to keep up!
Another technique that works well if your cowling isn't nicely painted inside is to apply the insulation then put a bead or ProSeal or RTV around the edge of the insulation to seal the edges. This will keep the dirt, oils, and water from getting behind the insulation and making a mess.
Of course, the area still needs to be clean and reasonably smooth for the insulation to stick. Do it once, and do it right, and it should last the life of the plane.
Vince Frazier
www.f1aircraft.com
Old 04-07-2013, 03:29 PM
Bevan Bevan is offline
It would seem to me that if one had a sustained engine compartment fire on an aircraft such as an RV, most of the fire would be in the lower cowl and cowl exit area. This means that the most vulnerable (to fire) areas is the lower cowl and the bottom aluminum skin of the cockpit. I would think that the firewall is sufficient as designed but the lower cockpit skin is where the protection should be applied. To that end, would the subject product work on the bottom skin? IE, would is stay stuck on despite the constant airflow and relatively low heat under normal operations? or would something else be better such as a stainless sheet over the aluminum?
I also suspect that the lower skin is also the pathway for the vast majority of engine (exhaust) noise entering the cockpit. So a 1/16 cover of self adhesive kiln insulation covered by a thin sheet of stainless attached with rivets or screws would make a pretty good sandwich for sound and heat protection, no?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-09-2013, 09:09 AM
vfrazier's Avatar
No, the Heatshield mat would not be appropriate for use on the exterior of the plane, nor would it be useful against direct flame.
It is good at reflecting and insulating against radiant heat. That makes it useful for keeping your feet cool or preventing scorch marks on your cowling near the exhaust pipes.
Vince Frazier
www.f1aircraft.com
