Old 04-01-2013, 03:39 PM
Abbygirl1 Abbygirl1 is offline
Default Garmin 195
OK, all the avionics gurus...........I re-inherited my old Garmin 195 from my son this weekend. (He's a C-17 aircraft commander, so I guess he really doesn't need it..lol). My question is this; the unit is like new, no scratches aor dings. I just need to know if there is any way to update the flight database in it. I see one for sale on Ebay that the seller CLAIMS to have been updated this March 2013. If this is true, how did he do it and what do I need?
Dad of an Air Force C-17 flight instructor
Old 04-01-2013, 04:09 PM
flyinga flyinga is offline
Check with Garmin. I'm not sure the 195 is still supported. If you're going to Sun n Fun they can probably do the upgrade there.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 04-01-2013, 04:27 PM
RobinHou RobinHou is offline
Default I think it is still available ...
http://www8.garmin.com/products/gpsm...databases.html
One?Time Update = $125.00
Two scheduled updates in one year = $150.00
Four scheduled updates in two years = $200.00
Yearly Subscription (13 Consecutive Cycles) = $600.00
Old 04-01-2013, 04:59 PM
Robin...I do believe you found it. Many thanks.
Old 04-02-2013, 01:56 PM
smiller smiller is offline
Perhaps that was my eBay listing you saw. I just updated my GPSMAP-195 to the DB that takes effect April 4th via the Garmin web site, but it cost only $49.95 for the USA. You can't put all of North America into the unit anymore so they allow you to choose subregions. I chose one that included all of the USA. Worked fine via the serial data cable, after I reduced the serial baud rate in the update app to 9600 baud.
Shannon Miller
RV-7A Fuselage
Old 04-02-2013, 02:24 PM
wirejock's Avatar
wirejock wirejock is offline
Default floppy disk
Does anyone know if they have the update on something other than floppys? I have a 195 also but have not seen a floppy drive in years!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-02-2013, 02:54 PM
You can update the GPSMAP-195 using a serial port and a data interface cable that comes with the GPS unit. If you don't have a serial port on your PC, one of those cheap USB-serial converters would probably work, although I haven't tested it.
Here's the database update info and prices:
https://fly.garmin.com/fly-garmin/av...ase_cycles.jsp
And here's where you go to update it via your serial port:
Like I said, it's only $49.95 to update the Jepp database in the GPSMAP-195 this way. No idea why the other site listed in a previous post lists it as $125. Maybe because they have to scrounge around for the floppy disks!
Shannon Miller
RV-7A Fuselage
Old 04-02-2013, 03:16 PM
DaAV8R DaAV8R is offline
Default 195 Update
Jeppeson was updating the 195 at Oshkosh as late as 2011 for $40.00. You might check with them during Sun and Fun.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 04-03-2013, 04:38 AM
Talked to Garmin. They said it was 49.95, and you have to get the USB-serial cable. Like previously posted, only download what area is essential to you to keep file size down.
Old 04-11-2013, 04:16 AM
Default 195 cable
Anyone know where I can get the cable to interface with my PC for the 195?
