Originally Posted by David Z
I quite often use a shorter bolt and/or a thin washer compared to what's called out. As long as there is thread out the end of the nut it is okay.
Not always.
Most fasteners in a RV are loaded in shear. For a structural fastener to properly carry the shear load, the parts should only be baring on the un-threaded shank of the bolt. In many instances, if a shorter bolt is used with a thin washer, there will be sufficient threads (minimum of one) showing outside the nut, but a thin part of the stack up may be baring on the bolt threads. Not a good practice.
Originally Posted by Bruce
David,
The AN's are structual screws.
Make sure they are the same AN #.
Structural screws (generally) have a portion of the shank that is un-threaded (like shown in the photo) for the reason mentioned above.
