Go Back   VAF Forums > Main > Safety
View Poll Results: Do you make radio calls even if you are the only one in the traffic pattern?
Yes 288 97.96%
No 6 2.04%
Voters: 294. You may not vote on this poll
Closed Thread
  #11
Old 03-31-2013, 05:50 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Yes - but there there is often radio-less aircraft at our field so a good lookout is essential.
Jim Sharkey
  #12
Old 03-31-2013, 06:23 AM
plehrke's Avatar
plehrke plehrke is offline
Default Look, Listen, Report
Jim Sharkey
Same at my home airport but looking should be first priority at all airports [even those with towers]. Listening is second priority and not done so well by most. Lots of distractions when preparing to land and we all need to practice listening. Reporting some distance out (i use 5 miles as we are in high traffic area and more then 5 miles would add confusion), entering downwind, and final are typical reports I provide even at 5:30am when everyone else is sleeping.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
  #13
Old 03-31-2013, 06:34 AM
JBPILOT JBPILOT is offline
Default This has happened also - -
2 announce at the same time, and you can't understand either, and one or both might be at the airport you are at. If I don't hear anything, I might announce a couple things at once, but at least 3 times.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2020 )
  #14
Old 03-31-2013, 06:43 AM
Paul K Paul K is offline
Yes, absolutely no reasonable reason not to!
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
  #15
Old 03-31-2013, 06:59 AM
kinger's Avatar
kinger kinger is offline
Yes, I gave flight instruction to a deaf (meant to type speech impediment) student (eventually) pilot. He could hear perfectly fine. The FAA gave him a LODA for his disability.
edit: very bad speech impediment
James King
RV-7
919
Last edited by kinger : 03-31-2013 at 08:29 AM. Reason: corrected for deaf to speech
  #16
Old 03-31-2013, 07:13 AM
VETE76 VETE76 is offline
We have a few radio less ac at our field that fly a lot. Then you get the two guys talking at the same time. Are they both at your airport? Next is the pilot who only transmits once, doesn?t hear anyone else and lands with no futher communications. then u have the student solo pilot who announces 33 downwind and he?s actually upwind on 24, the intersecting runway. Then the idiots taking off at opposite ends of the same runway. happens at 2 airports in ny state that neither end can see the other end of the runway and maybe 1 or both are radio less, it?s a calm wind and one or both could be student pilots in radio less ac. oh my god should I continue? Call 10 miles out and follow ALL procedures and maybe, just maybe someone might live longer!! i am almost willing to bet most every pilot reading this has seen or heard or experienced some the above in as short a time as 2-3 yrs of flying and almost all of us has been in one the scenarios
  #17
Old 03-31-2013, 07:37 AM
g zero g zero is offline
Originally Posted by kinger View Post
Yes, I gave flight instruction to a deaf student (eventually) pilot. He could hear perfectly fine. The FAA gave him a LODA for his disability.
If he could hear perfectly fine , must not have been deaf !
And yes 90% of the time , 100% on short final .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
  #18
Old 03-31-2013, 08:27 AM
kinger's Avatar
Sorry, not enough coffee... He had a very bad speech impediment... One really couldn't understand him on the radio.
James King
RV-7
919
  #19
Old 03-31-2013, 08:55 AM
DiscoverThruCruisin''s Avatar
DiscoverThruCruisin' DiscoverThruCruisin' is offline
Smile yes
Yes, yes, yes, yes, yes
a simple yes
  #20
Old 03-31-2013, 09:04 AM
aerhed aerhed is offline
Everywhere but here at home. The antelope don't monitor unicom.
Actual repeat offender.
Closed Thread
