Go Back   VAF Forums > Model Specific > RV-6/6A
  #51
Old 04-19-2013, 11:26 PM
Snowflake's Avatar
Originally Posted by 6 Gun View Post
Not in the plans but I moved my stops for aileron to outboard bracket and used #3 bolts as stops.
I missed this on first read... Putting your stops at the other end of the aileron means that when you hit the stop, you are apply a twisting load to the aileron. Having the stop at the inboard end means that hitting the stop does not stress the aileron itself, just the stop.
Rob Prior
Old 04-19-2013, 11:52 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
I am busy skinning my fuselage and I can confirm that on the 6 the two belly skins are .025 The front side skins are .032
Old 04-20-2013, 12:44 AM
longranger's Avatar
I like this idea for aileron stops. I got a 3/4" delrin rod from ACS and am going to try to make stops to fit over the pushrod spacer.
PS: 1000th Post! Sometimes I feel like I spend too much time here...
RV-7 TU 904KM (reserved)
Construction Log
Old 04-20-2013, 07:59 AM
6 Gun 6 Gun is offline
Talking stops
Thats what i love about this forum i will remiedy the stops.
Thanks Bob
Old 04-20-2013, 10:34 AM
rvbuilder2002's Avatar
I guess I remembered incorrectly. I new for sure the sides skins are .032, and that the forward bottom is .040.
Doesn't matter... As I have said before, I have seen with my own eyes, these screws carrying load during static tests.
The arm chair engineers would probably be quite surprised to see how much the wings deflect when loaded to 6 G's...
Old 04-20-2013, 10:49 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
I concur. They would certainly be surprised!
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 04-20-2013, 03:38 PM
Snowflake's Avatar
On a -6, or a -7? Just trying to narrow down what testing has been done on a -6 wing. Previous reports were that the -6 wing was tested to its limits at the factory *without* the belly skin.
I have witnessed some static tests in person, and wouldn't at all be surprised how far the wing deflects at 6G. Heck, watching an Airbus wing curl up like a pretzel on takeoff is disconcerting enough. :P
Rob Prior
Old 04-20-2013, 05:01 PM
On a -6, or a -7?
I don't see that it really matters
The wings on all the models flex under +G load.
The top skins get slack and the bottom skins get very tight (as expected).
With all of the screws in place, some of the load being carried in the bottom wing skins is transfered to the fuselage belly skins (regardless what model).
Old 04-20-2013, 06:31 PM
Default Teting
It does matter which wing was being tested could you be more to the point about which model and under what condition it was tested as testing does matter and how it was carried out havent heard of any RV6 testing other than Vans.
Thanks Bob
Old 04-20-2013, 07:26 PM
The many static tests I have witnessed, and been involved in, were at Van's.
There actually has been other testing done though... Years ago, some of the European country's required the first example built there to be static tested to limit load (I don't think that is the case any longer though).
