Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 03-27-2013, 08:58 PM
Scott Hersha Scott Hersha is offline
The screws that are missing are #8 screws. There should be #8 plate nuts in the inboard edge of the lower inboard wing skin to accept the screws attaching the belly skin. You could just install the screws if the plate nuts are there. The question is, what structural loads have been imposed by the lack of these screws? If the plate nuts are not there, something important was missed by the builder. Maybe you should keep looking. BTW - good job noticing this omission and investigating it.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 03-27-2013, 09:00 PM
Snowflake's Avatar
Originally Posted by ChiefPilot View Post
No, underneath it stops just aft of the tanks.
Now that you mention it, I should know that because that's where I have trouble keeping the free end of the rubber filler strip in place... I remember it's right beside the fuel drain.
I can't remember ever seeing screws under there on mine, either, but i'll definitely be checking it the next time i'm at the airport...
Rob Prior
Old 03-27-2013, 09:04 PM
az_gila's Avatar
az_gila az_gila is offline
Post
The joint (overlap) should be bolted per the previous link. http://www.vansairforce.com/communit...99&postcount=7
You might be able to use dome head #8 screws and self locking nuts installed from the top if you remove the upper wing/fus. fairing strip.
If this is possible, you might be able to drill the holes and insert nuts/bolts without taking the wings off.
Check with Vans to see if this is acceptable - it probably is.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-27-2013, 09:11 PM
fehdxl fehdxl is offline
Gil,
What's the shear strength of a dimpled screw joint versus just a hole with a dome head screw and nut? My gut says the dimpled is stronger, which is what is called for by Van's in the plans. Sure, anything is better than nothing, but if one wants the full 6 positive G capability...
I suppose some sort of dimple extension/riveter apparatus could be fabricated to make dimples without removing the wing...sounds tough though.
Fly safe,
-Jim
Old 03-27-2013, 09:13 PM
JonJay's Avatar
JonJay JonJay is offline
I am sure it would be Gil but that opening is tigheeeet. Unless you have eyes on your forehead or are really good with a mirror it would be tough at best.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-27-2013, 09:29 PM
roee roee is offline
Originally Posted by JonJay View Post
It is not a service or airframe issue, it is a construction issue. Who knows what impact it may or may not have on the strength of the wing.
I would be more concerned with what else the builder felt was "unnecessary".
Exactly. This kind of omission in construction makes the entire airplane suspect. And if the builder was trying to brush off this issue with nonsensical talk about service bulletins (a red herring), that again makes the airplane and the builder even more highly suspect.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 03-27-2013, 09:44 PM
FitzRX7 FitzRX7 is offline
Well, this wasn't the builder that mentioned the bulletin thing. The guy who's name is on the aircraft as the builder actually passed away 10ish years ago.
It seems like I've got the right idea then, that these are completely necessary for the plane to perform as advertised. Hopefully it gets fixed soon.
Thanks for everyone's inputs, I really appreciate it.
One last thing, how easy would it be to get the FAA examiner person to sign off an aircraft as airworthy with a problem like this? Why wasn't it caught at whatever kind of inspection gets done for that? Please excuse my ignorance on this, hopefully one day I'll build a plane!
Old 03-27-2013, 10:34 PM
Good question. Easy, depending on who did the inspection. A good DAR who is familiar with RV's and did a thorough technical inspection would have caught this problem. If, on the other hand, the inspection was done by a FSDO guy without any real familiarity with RV's, then something like this could easily slip through the cracks. The legalities of the airworthiness inspection are mostly bureaucratic. It is up to the builder to make sure the airplane is actually airworthy, and that includes choosing the right DAR to do a thorough and meaningful inspection. Not everyone does.
So if you're still interested in buying this airplane, you should seriously consider having it inspected from head to toe by a qualified person familiar with the type. Not for legalities, since it has already been deemed legally airworthy, but for your own peace of mind, to know what if any other major deficiencies in construction may be lurking in there. With something as blatant as what you've found, there's bound to be more.
Roee Kalinsky
Old 03-27-2013, 11:39 PM
az_gila's Avatar
Exclamation
Originally Posted by fehdxl View Post
Gil,
Fly safe,
-Jim
Yes... the dimpled joint would definitely be stronger in shear.
Thats exactly why I said to check with Vans first...
It would be difficult to get fingers, tweezers, swivel sockets extra down in the narrow gap as JonJay says... but if you can get in there, it will be less work than wing removal on a -6, and even less if it's a -6A.
Gil Alexander
Old 03-28-2013, 07:00 AM
Mel's Avatar
Mel Mel is offline
I have to go along with everything said to this point.
I would not consider buying this aircraft without a complete condition inspection by someone very familiar with the RV-6.
I have found things that 99.9% of FSDO inspectors would have missed simply because they are not familiar with a particular model.
The most important thing that I've found on an RV-6 is 2 missing steel splice plates where the 2 wings mate. This is very critical and would never be noticed by someone not familiar with the RV-6.
The missing screws you mention are necessary for safe operation of the aircraft.
Good job on noticing this discrepancy. There are probably others. Make sure they are found.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
