Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 03-26-2013, 01:47 PM
ratc's Avatar
ratc ratc is offline
Default Propeller bolt upgrade 3/8" to 7/16"
I have a Lycoming 0-320 D3G (160 hp) with 3/8" prop bolts, what is the best way to upgrade to 7/16" ?
Is it acceptable to have 3/8" engine bolts and 7/16" propeller bolts?
Comments for/against OR alternative solutions gratefully received.
Thanks in advance.
Andy
RV-4
#4411
G-RATC
Old 03-26-2013, 02:05 PM
Mel's Avatar
Mel Mel is online now
I have ben told by Lycoming and several propeller manufacturers that this is acceptable and have been running this combination since May of 1993.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-26-2013, 02:10 PM
penguin penguin is offline
Saber Engineering will sell you some new prop flange bushes (http://www.sabermfg.com/bolts.htm), its relatively straight forward to press out the old ones and pull in the new - can be done with the engine in the airframe.
Pete
Old 06-13-2020, 02:05 AM
bardample bardample is offline
Thumbs up Propeller bolt upgrade
I have the same engine , and at over haul , before installation,I had the shop put new flanges in the hub so I could install the Sensenich prop that had 7/16 bolts . As suggested if you intend to use a prop that will be using 7/16 bolts , that?s what needs to be done. When I contacted Lycoming and Sensenich they offered no other solution , apart from change over of prop or engine. I should say I haven?t flown the combination yet , but I?m not expecting any issue. Good luck.
