Pirep
LOTs of folks ask about "best landing light". Some what like the question of what's the best EFIS to put in your panel: you need to ask "What kind of flying do you want to do? What kind of airports do you expect to land at? Do you want to WigWag the lights?"
I previously wrote ( http://www.vansairforce.com/communit...ad.php?t=87515 ):
I've been flying the prototype Duckworks LED wingtip lights for just over a year. I have a 3 position switch for my lights, OFF; WIG/WAG; LANDING. I WIG/WAG the Duckworks LEDs and for landing the Duckworks LEDs are on steady AND I have a pair of Duckworks HID in the leading edges of the wings. The LEDs have been on either WIG/WAG or steady for all of my flights.
The LEDs project a bright focused beam. The HID's are BRIGHT and a bit wider beam. The LEDs will illuminate the blue taxi reflectors the complete distance at Independence (7S5) which is 3100+ feet.
The Hillsboro Tower has commented how visible my plane is WIG/WAGging the LED's. I'll try to take some pictures in the next few days and post them.
(Note: Don of Duckworks is a long time friend. He was primary TC for my CH601HDS. I have no financial interest in Duckworks.)
Additional info. I'm very happy with my lights and would make the same choice today. The HIDs put out more light than the LEDs. I have an Archer VOR antenna in the right wing tip. Wig-Waging the LED's causes interference with the ILS, so I turn off the lights when flying an ILS. I have not noticed interference with VOR's and I have not tested for ILS or VOR interference with the lights on. I generally don't use VOR's for navigation.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
