using posterboard as rear skirt template
I've got the gap between the canopy and fuse all taped up and ready to glass but after an initial test run using wax paper as a barrier between the two I've decided to try something else less prone to creases and bubbles. I would appreciate any suggestions as to what I could coat the posterboard with to prevent the epoxy from sticking to it. Thanks. Jim.
