Old 03-25-2013, 02:06 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Honestly, What would you do?
So while tidying up my wiring getting ready to rivet on the top skin, I end up with this.
I don't like it, but redoing pins, end connectors and bundle ties would take a LOT of time and probably really diminish my motivation.
I'm pretty sure that it would just be ok if I leave it, which I'm leaning towards, but I'm curious what others would do. I'm guessing I'll get a lot of "build on" responses, but I'm sure some you would freak over leaving this be. By the way, it's behind the panel and no will really ever see it, except you folks!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 03-25-2013, 02:09 PM
Clarkie Clarkie is offline
If it were me, I'd redo it. Perfectly acceptable I'm sure, but that would drive me crazy.
Tom Clark
RV-6 Sold
F1 Rocket
Lake Norman Airpark - 14A
Old 03-25-2013, 02:29 PM
flyinga flyinga is offline
Build on. With luck you will never see it again.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 03-25-2013, 02:37 PM
N15JB N15JB is offline
Don't ask; don't tell.
Jim Berry
RV-10
Old 03-25-2013, 02:49 PM
jcaplins's Avatar
jcaplins jcaplins is offline
if it were me I would pull just a little bit of slack out of each wire from between each of your wire ties and Adel clamps to spread out the extra wire length throughout the entire run. (god, I hope that makes sense)
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 03-25-2013, 02:50 PM
Brantel's Avatar
Brantel Brantel is offline
As someone that is very familiar with future upgrades...you may end up someday wishing you had a little extra slack in one of them wires!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-25-2013, 02:51 PM
pa38112 pa38112 is offline
I would get a spool of lacing tape ( http://www.aircraftspruce.com/catalo...?clickkey=3874 ) and tie bunches of three or four wires together 1/3rd the distance before and after the apex of the bend. This will give some support to the individual strands and will look half decent.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 03-25-2013, 02:57 PM
Flying Scotsman Flying Scotsman is offline
I'd fix it and make it right...
"PREFERRED DISCRETE WIRE HARNESSES
Harnesses exhibit a neatly organized layout, with smooth bends and sufficient stress relief. Connector cable clamps and cable straps are
properly set. NASA-STD-8739.4 [ 19.6.1.e ]"
"ACCEPTABLE UNIFORM CONDUCTOR TENSION
The conductors exhibit uniform tension throughout the length of the harness. No bunching, bowing, looping, kinks, etc.
NASA-STD-8739.4 [ 19.6.1.e.3 ]"
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 03-25-2013, 03:36 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep.
Double yep.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-25-2013, 04:32 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Yep.
Double yep.
Triple yep
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
