  #11
Old 05-29-2013, 08:42 AM
gtmule gtmule is offline
BTW, cutting a hole in stainless foil is easy. Just use the corner of a razor blade to make a series of connecting punctures...poke, poke, poke.
Yep, recognize that ALL your foil edges will be covered in firestop caulk or tape, and really any method of cutting is fine, you'll never see the edge once you're done.
For the pass throughs, I did the tube and sheet with firesleeve, but made them myself. Here is a picture before the foil went on:
The white insulation is just held up with a bit of RTV at this point, eventually the firesleeve/firestop caulk and the various items mounted will hold the foil on, which will support the insulation.
And here's an "after" picture:
I'll install hose clamps and more firestop to seal everything once I know I'm done pulling wires. I have lots of small passthroughs, rather than a couple large ones, just because I was working with existing holes. If you were building a new airplane, I'd recommend two large (1", maybe more) ones.
You might be able to see in the second picture that I slid the firsleeve over the stainless tube and used a bit of firestop to bond the end of the firesleeve to the foil. This seals it, but also turned out to be a really good "mount" for the foil, helping to stabilize it.
I'm considering making up a batch of pass-throughs for my hangar neighbor who is building a -9A. If anyone else wants some, let me know what size we can come up with a price, I guarantee they'll be cheaper than the ones spruce has (which are absurd, at $45 a pop).
Macon, GA (KMCN)
RV-7, Niner Fife Victor
Old 05-29-2013, 09:53 AM
southtarnation's Avatar
southtarnation southtarnation is offline
I would buy two or three. And am ready for them pretty soon.
Jesse
'89 RV-4, N2626C - purchased flying
Converted to Fastback - Sliding Canopy - Tall Gear
Dynon Skyview w/ acc. & VP-x Sport
Catto 3-Blade (gen. 1)
Based: KPGD
Old 05-29-2013, 11:22 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Count me in on the pass-troughs as well .. I have no holes yet - so maybe a few in 1" and in 1/2" would do ... What material are they made off ? looks like 4130 tube welded to a plate .. which you then rivet on with Monel rivets ?? What is a good source for the insulation material ?
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 05-29-2013, 03:01 PM
I used 304 stainless, .032" thick and #8 screws to do the passthroughs, but rivets would obviously work just as well.
The insulation is mcmaster part # 93315K51 (1/4" ceramic insulation 2'x20') the foil is 3254K16 (.002" 321 stainless 20"x10' roll). Mcmaster also sells aluminum standoffs (ex: 92510A642 for a spacer with a clearance hole for a 3/16 screw, 1/4" thick, 3/8" OD).
I've got plenty of insulation and foil left (more than half of each), if someone wants to buy it off me, though mcmaster ships it so much cheaper than I can that it may not make sense....maybe for someone local?
Macon, GA (KMCN)
Old 05-29-2013, 05:08 PM
DanH's Avatar
DanH DanH is offline
The insulation is mcmaster part # 93315K51 (1/4" ceramic insulation 2'x20')?
Hmmm...a low density wool.
Fiberfrax is a Unifrax trade name covering a whole range of ceramic insulation products. Among homebuilders the word means Fiberfrax 970 felt (the manufacturer calls it "paper"). I think it was Rutan who introduced it to us.
http://www.fiberfrax.com/files/Fiberfrax-Papers.pdf
It is a dense felt (about 10 lbs per cubic foot) held together with an organic binder. It forms a nice firm sheet, easy to trim to exact dimensions and smoothly cover with metal foil or fiberglass fabric.
The organic binder (glue) makes it more durable than a wool blanket product which is simply tangled long fiber. The durability issue is perhaps important given that firewalls vibrate.
Spruce, Wicks, etc all carry 970.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-29-2013, 07:29 PM
It's pretty well secured, but if it doesn't hold up, (the only failure mode I could see is it pilling up on the bottom) it won't be that bad to start over and try something else.
Macon, GA (KMCN)
Old 02-28-2020, 02:16 AM
flyingbeaver26's Avatar
flyingbeaver26 flyingbeaver26 is offline
Default Inside FW treatment
I've been reading up on all the old threads about FWF insulation and sound dampening... I've got foil and fiberglass on order with McMaster. But just curious, is the general guidance to leave the inside surface of your firewall completely bare? No paint, no insulation?
Since this SS and fiberglass mat will buy extra time to protect the pilot if a FWF fire ensues, you don't want anything inside the cockpit smoldering and chocking you as you make an emergency landing. So I'm thinking I need to break out the paint stripper and remove the paint in this area, right?
Old 02-28-2020, 12:59 PM
DanH's Avatar
Yes and yes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-28-2020, 04:48 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Pass throughs for a few bucks each
Steel EMT fittings, https://external-content.duckduckgo....&nofb=1Cockpit fitted on the engine side with firesleeve, filled when finished with FireBarrier2000. Cabin side showing nuts, visible through the panel cutout:
Firewall side, before wires and cables pulled. The requisite cables and wires are now in place, and all fit with room to spare:
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 02-28-2020, 07:43 PM
Checkmate's Avatar
Checkmate Checkmate is offline
Default Thicker SS Option No Interior Firewall Paint
I used .005 SS Shim Stock, 1/8" FiberFrax, 3M Barrier 2000+. No wrinkled tinfoil look like the thinner stuff but some oil canning is to be expected around the areas where you attach items over it but still easy to work with, gloves still a must. Also a hydraulic punch works great for making nice clean round holes. Ordered everything from McMaster-Carr.
All steel or stainless purchased or custom made fittings used for any pass through items. No painted surfaces on the cockpit side.
https://lh3.googleusercontent.com/Rs...M=w800-h450-no
https://lh3.googleusercontent.com/77...M=w450-h800-no
https://lh3.googleusercontent.com/xh...g=w800-h450-no
https://lh3.googleusercontent.com/Bg...k=w800-h450-no
Ed
RV-9A - Down for Panel & Engine Conversion
1946 Piper J-3 Cub - Flying
VAF Donation Paid Feb. 2020
