Old 03-20-2013, 09:54 AM
gear1 gear1 is offline
Default Canopy Cracks
About a year ago a major crack developed in my RV8 canopy on a cold morning (about -10C) departure from Truckee CA at the "standard" locatation at the rear canopy bow. With the help of Jay Pratt (Borrowed Horse) and Danny King (Beautiful Doll) I installed a new canopy. Danny had already made two canopy replacements due to cracks, and suggested that the concept of using rubber grommets in oversize rivet holes in the plexiglas might work. The idea is that the grommets will allow some relative motion between the canopy and canopy frame during temperature changes. The grommets were made from RC model silicon fuel hose, sliced to canopy thickness. Now, a year later, Danny's idea seems to be working. Flying out of Pagosa Springs, CO, this winter we have experienced temperatures in flight as low as -12C (10F), with no canopy cracking.
Thanks, Danny!
Craig Taylor
RV8 flying
2020 VAF dues paid with thanks
Navy A7E Vietnam era
Ret. Corporate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 03-20-2013, 11:42 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I think you mean "Danny" King, unless he is now using an alias to avoid a posse....which, with Danny, is not out of the questions.
I did his grommet trick on my replacement as well, and think it is a grand idea. Only time will tell if it works as well as it seems like it should.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-20-2013, 12:03 PM
gasman gasman is offline
Progressive slots would really be the answer. But very difficult to do.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-21-2013, 06:18 AM
Thank you, Paul. I have edited my post, with a very red face!
Craig Taylor
RV8 flying
Old 03-21-2013, 06:36 AM
Seems like a common area of cracking is the "rear canopy bow".
Something must be going on in that area when in cold temperatures, perhaps the frame is changing shape with temperature change?
Has a canopy cracked in that area using Sikaflex?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-21-2013, 09:32 AM
Ironflight's Avatar
I actually think that location is highly stressed because of the change in diameter of the frame tubing - there is a weld bump at that point, and the canopy gets pulled tightly across it. Any imperfections in the canopy edge or holes in that area are more likely to let go when the thermal gradients build up.
At least that's my theory.
Paul F. Dye
